Intel® C++ Compiler
The behavior ICC triggers unused_function warning is odd
Xue__Liang
I'm using ICC Version 19.0.6 Build 20191202 to build on Ubuntu 18.04.1.
I found that the warning [-Wunused_function] only take class into consideration, meaning if the member function of a class is never referenced, it trigger the warning, however while if a free function is never referenced, no such warning will be shown. I also try on GCC, which shows a opposite behavior.
For example, the following cpp codes will trigger no warning by ICC, but a warning [-Wunused_function] by GCC.
static void SFoo() { return;}
int main()
    return 0;
Is the behavior of ICC expected?
RahulV_intel
Could you also specify your gcc version?
You are right, in case free function is not being referenced, "gcc" throws a warning, but "icc" doesn't. However, in case class member function is not being referenced, both icc and gcc are not throwing any warning. Tried with icc version 19.1 and gcc version 7.4.0 using "-Wall" flag.
-Rahul
Xue__Liang
Hi Rahul,
The GCC version is: gcc (Ubuntu 7.4.0-1ubuntu1~18.04.1) 7.4.0
The result you see is the same regarding GCC behavior, but for ICC, your result differs from mine.
Mine result shows ICC throws warning for class, and only for class.
My ICC Version  is 19.0.6 and yours is 19.1, maybe that's why the different behavior.
What's the expected behavior?  throw warning or not for class?
--Liang
RahulV_intel
Hi Liang,
We are investigating this query with the Intel engineering team and we will get back to you at the earliest.
-Rahul
Viet_H_Intel
I don't have the exact icc/gcc versions which you have. But I don't see any differences with icc 19.0.5, 9.1.0, gcc7.3.0 and 8.1.0
$ icc -V
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.5.281 Build 20190815
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
$ icc t.c -c -Wunused-function
t.c(1): warning #177: function "SFoo" was declared but never referenced
$ gcc t.c -c -Wunused-function
t.c:1:13: warning: ‘SFoo’ defined but not used [-Wunused-function]
$ icpc t.cpp -c -Wunused-function
t.cpp(1): warning #177: function "SFoo" was declared but never referenced
$ g++ t.cpp -c -Wunused-function
t.cpp:1:13: warning: ‘void SFoo()’ defined but not used [-Wunused-function]
$ g++ t.cpp -c
$ icpc t.cpp -c
$ gcc t.c -c
$ icc t.c -c
$ cat t.c
int main()
    return 0;
$ cat t.cpp
int main()
    return 0;
How do I reproduce the differences?
Xue__Liang
Hi Viet,
My ICC version is Version 19.0.6 Build 20191202, different from yours. It could be the reason why you cannot reproduce the issue.
--Liang
Viet_H_Intel
Can you add -ww177 to your command line to see if the compiler emits the warning?
Xue__Liang
Hi Viet
After experiment, the behavior is
icc -ww177:  both free function and class member function can emit warning#177
icc -Wall:       only class member function can emit warning#177
Does the behavior expected?
--Liang
Viet_H_Intel
It isn't expected, but you can use -ww177 as a workaround. And the latest compiler emits the correct warning to.
Viet_H_Intel
Let us know if this is still an issue. Otherwise, we will close it.
Viet_H_Intel
We will no longer respond to this thread.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
