Hi everyone!
The default behaviour of Intel C++ compiler 11 for Windows is to ignore unsupported compiler options (and output a warning). Is there any way to change this behaviour? I would like compiler to output an error and non-zero return code when it meets unsupported compiler option. Is it possible without writing special script that analyzes compiler output?
Thanks in advance,
Rostislav
If things work as they should be, the "/we10006" option or "/Qdiag-error:10006" should work. But because this warning is from the driver, not compiler itself, those two options does not work.
I'll create a bug report for this.
Right now I don't see any workaround.
Quoting - Jennifer Jiang (Intel)
This bug has been fixed some time ago. Please upgrade to the latest 11.1 update (update 6). (Update 4 or newer should have the fix as well)
Jennifer
Jennifer
Topic Options
