Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Turn off unsupported compiler options ignoring?
Hi everyone!
The default behaviour of Intel C++ compiler 11 for Windows is to ignore unsupported compiler options (and output a warning). Is there any way to change this behaviour? I would like compiler to output an error and non-zero return code when it meets unsupported compiler option. Is it possible without writing special script that analyzes compiler output?
Thanks in advance,
Rostislav
Highlighted
If things work as they should be, the "/we10006" option or "/Qdiag-error:10006" should work. But because this warning is from the driver, not compiler itself, those two options does not work.
I'll create a bug report for this.
Right now I don't see any workaround.
Highlighted
Thanks. Then I'll write a wrapper-script...
Highlighted
This bug has been fixed some time ago. Please upgrade to the latest 11.1 update (update 6). (Update 4 or newer should have the fix as well)
Jennifer
