Intel® C++ Compiler
Two bugs with icpc 13.0.0.0
VinceRev
Hello.
I think I've found two bugs in icpc 13.0.0.0.
This is illustrated by the following program compiled with "icpc -std=c++0x icpcbugs.cpp -o icpcbugs"
// Preprocessor
#include <iostream>
#include <type_traits>
// Annoying warning 2922 with icpc (ICC) 13.0.0 20120731
// Note: there is also the same bug with warning 488
// icpcbugs.cpp(11): warning #2922: template parameter "<unnamed>" cannot be used because it follows a parameter pack and cannot be deduced from the parameters of function template "warningbug2922"
template<typename T, class... Args, class = typename std::enable_if<std::is_fundamental<T>::value>::type>
void warningbug2922(const T& x, const Args&... args);
template<typename T, class... Args, class>
    std::cout<<sizeof(T)<<" "<<sizeof...(Args)<<std::endl;
// Compilation error with icpc (ICC) 13.0.0 20120731
// icpcbugs.cpp(32): internal error: assertion failed at: "shared/cfe/edgcpfe/il.c", line 16057
struct Test {static constexpr bool ok();};
constexpr bool Test::ok() {return true;}
template<typename T, class = typename std::enable_if<std::is_same<T, Test>::value>::type, class = typename std::enable_if<T::ok()>::type>
void assertionfailed(const T& x)
    std::cout<<x.ok()<<std::endl;
// Main
int main()
    warningbug2922(5.);
    assertionfailed(Test());
    return 0;
Can you confirm these bugs ?
Will they be corrected in a next release ?
Thank you very much.
Kittur_G_Intel
Hi, Let me look into it and get back to you... Regards, Kittur
Judith_W_Intel
I have entered the assertion failure in our bug tracking database as DPD200239941. This seem to be a bug in our implementation of the new c++11 constexpr feature. Thank you for reporting it.
Kittur_G_Intel
Hi, Yes, I could reproduce and have filed the issue (bug) with the developers. I'll let you know as soon as there's an update accordingly. Appreciate much for your patience. Regards, Kittur
Judith_W_Intel
Regarding the warning, Although technically this warning is correct, the template parameter is being used as part of SFINAE so it is being "used" in that sense. Perhaps we should only warn if the template parameter is named ... In any case I have entered DPD200239943 in our bug tracking database to look into the problem. Thank you for reporting it. Judy P.S. I see your comment about warning 488 in the example. Do you have a test case for that one?
VinceRev
Thank you very much. Note also the warnings 2922 and 488, that can be thrown for no relevant reason. In the previous code, if you merge the definition and the declaration, the warning 2922 is not thrown (so it seems to be an error of definition/declaration matching somewhere in icpc). I know that C++11 is very recent, but I have written a small library that use a lot of metaprogramming and CRTP techniques thanks to the C++11 type traits, and I have hundreds of no relevant warnings from icpc (and for the moment I cannot compile the code with intel due to the reported error (but it compiles well with g++ 4.6.3 and g++ 4.7.2). Regards, Vincent
VinceRev
@Judith. Regarding to the warning 2922, I think that throwing a warning only if the parameter is named is a perfect option (because this kind of SFINAE using enable_if will become more and more used). For the warning 488, I've seen it during the compilation of my library, so I will try to reproduce the problem in a small example (but it seems very comparable to warning 2922). Regards, Vincent
VinceRev
I have successfully reproduced the problem of warning 488: --------------------------------------------------------------------- // Preprocessor #include < iostream > #include < type_traits > // This code throws warnings 2922 and 488 about the SFINAE parameter. // If the SFINAE template parameter is not named, it would be more convenient // to not throw a warning. // Compiled with icpc (ICC) 13.0.0 20120731 struct Test { template< class... Args, class = typename std::enable_if< sizeof...(Args) != 0 >::type > Test(const Args&... args); }; template< class... Args, class > Test::Test(const Args&... args) {} // Main int main() { Test(42); return 0; } --------------------------------------------------------------------- Regards, Vincent
Kittur_G_Intel
Hi Vincent, Thanks for the reproducer which I've passed on to the developers in the issue I've already filed. Will keep you updated, appreciate much Regards, Kittur
