Anybody has install C++ compiler in Ubuntu 12?
is It works well?
I have it working on OpenSuse 12.2, which contains roughly the same kernel and gcc versions.
It works very well, in spite of not being officially supported.
I have installed Intel C compiler in prevoius versions of Ubuntu, and it worked. I have finally abandoned Ubuntu, since Unity was just unbearable, and administration tools were too fragmented (compared to Suse).
No, it doesn't work well. But there is workaround here: http://software.intel.com/en-us/forums/topic/326646
The underlying problem is that the install script may not be executed correctly under Ubuntu's default dash system shell.
You need to (temporarily) switch to bash for installation:
$ sudo rm /bin/sh
$ sudo ln -s /bin/bash /bin/sh
Or if you don't have (sudo) root rigthts, change the Shebang line in the install scripts (.sh) from #!/bin/s to #!/bin/bash.
Then start installation. If you however did unsuccessful installs before you may need to remove /root/.rpmdb or $HOME/.rpmdb first to start the installer again. If you need more help, let me know what exactly fails.
Regards, Hubert.
Hi, I just got a single board computer which contains a Intel Atom E3826 processor. This board is the conga IA3. I want to run Linux in this single board computer, specially Ubuntu so I would like to know if this is possible or if it is necessary to install any BSP.
Best regards.
Javier
Best regards.
Javier
can any1 tell me the procedure of porting linux on intel atomE3826 board
