I am trying to build zlib 1.2.8 with icc and icpc on Ubuntu 14.04. I get the following messages when I run ./configure --prefix=/usr/local/zlib1.2.8.
Then when I type make fails ld: cannot find -lstdc++. Any comments appreciated.
Ashwin.
Checking for shared library support...
No shared library support; try without defining CC and CFLAGS
Building static library libz.a version 1.2.8 with icc.
Checking for off64_t... Yes.
Checking for fseeko... Yes.
Checking for strerror... No.
Checking for unistd.h... Yes.
Checking for stdarg.h... Yes.
Checking whether to use vs
Checking for vsnprintf() in stdio.h... No.
WARNING: vsnprintf() not found, falling back to vsprintf(). zlib
can build but will be open to possible buffer-overflow security
vulnerabilities.
Checking for return value of vsprintf()... Yes.
Checking for attribute(visibility) support... Yes.
ind -lstdc++
(exit code 1)
=== ztest3899.c ===
#include <sys/types.h>
off64_t dummy = 0;
icc -c -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 ztest3899.c
=== ztest3899.c ===
#include <string.h>
#include <errno.h>
int main() { return strlen(strerror(errno)); }
icc -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -o ztest3899 ztest3899.c
(exit code 1)
=== ztest3899.c ===
#include <unistd.h>
int main() { return 0; }
icc -c -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR ztest3899.c
=== ztest3899.c ===
#include <stdarg.h>
=== ztest3899.c ===
#include <stdio.h>
#include <stdarg.h>
#include "zconf.h"
int main()
#ifndef STDC
choke me
#endif
return 0;
=== ztest3899.c ===
#include <stdio.h>
#include <stdarg.h>
int mytest(const char *fmt, ...)
char buf[20];
va_list ap;
va_start(ap, fmt);
vsnprintf(buf, sizeof(buf), fmt, ap);
va_end(ap);
return 0;
int main()
return (mytest("Hello%d\n", 1));
icc -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -o ztest3899 ztest3899.c
(exit code 1)
vulnerabilities.
=== ztest3899.c ===
#include <stdio.h>
#include <stdarg.h>
int n;
char buf[20];
va_list ap;
va_start(ap, fmt);
n = vsprintf(buf, fmt, ap);
va_end(ap);
return n;
int main()
icc -c -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf ztest3899.c
=== ztest3899.c ===
#define ZLIB_INTERNAL __attribute__((visibility ("hidden")))
int ZLIB_INTERNAL foo;
int main()
return 0;
ALL = static all64
AR = ar
ARFLAGS = rc
CC = icc
CFLAGS = -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN
CPP = icc -E
EXE =
LDCONFIG = ldconfig
LDFLAGS =
LDSHARED = icc
LDSHAREDLIBC = -lc
OBJC = $(OBJZ) $(OBJG)
PIC_OBJC = $(PIC_OBJZ) $(PIC_OBJG)
RANLIB = ranlib
SFLAGS = -O3 -ip -D_LARGEFILE64_SOURCE=1 -fPIC -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf -DHAVE_HIDDEN
SHAREDLIB =
SHAREDLIBM =
SHAREDLIBV =
STATICLIB = libz.a
TEST = all teststatic test64
VER = 1.2.8
Z_U4 =
exec_prefix = ${prefix}
includedir = ${prefix}/include
libdir = ${exec_prefix}/lib
mandir = ${prefix}/share/man
prefix = /usr/local/zlib-1.2.8
sharedlibdir = ${libdir}
uname = Linux
./configure --prefix=/usr/local/zlib-1.2.8
Sun Aug 24 13:37:37 IST 2014
=== ztest4124.c ===
extern int getchar();
int hello() {return getchar();}
icc -c ztest4124.c
... using gcc
Checking for obsessive-compulsive compiler options...
=== ztest4124.c ===
int foo() { return 0; }
icc -c -O3 -ip -D_LARGEFILE64_SOURCE=1 ztest4124.c
=== ztest4124.c ===
icc -w -c -O3 -ip -D_LARGEFILE64_SOURCE=1 -fPIC ztest4124.c
icc -shared -Wl,-soname,libz.so.1,--version-script,zlib.map -O3 -ip -D_LARGEFILE64_SOURCE=1 -fPIC -o ztest4124.so ztest4124.o
(exit code 1)
=== ztest4124.c ===
off64_t dummy = 0;
icc -c -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 ztest4124.c
=== ztest4124.c ===
#include <string.h>
#include <errno.h>
icc -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -o ztest4124 ztest4124.c
(exit code 1)
=== ztest4124.c ===
#include <unistd.h>
icc -c -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR ztest4124.c
=== ztest4124.c ===
#include <stdarg.h>
=== ztest4124.c ===
#include <stdio.h>
#include <stdarg.h>
#include "zconf.h"
int main()
#ifndef STDC
choke me
#endif
return 0;
=== ztest4124.c ===
#include <stdio.h>
#include <stdarg.h>
char buf[20];
va_list ap;
va_start(ap, fmt);
va_end(ap);
return 0;
int main()
icc -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -o ztest4124 ztest4124.c
(exit code 1)
vulnerabilities.
=== ztest4124.c ===
#include <stdio.h>
#include <stdarg.h>
int n;
char buf[20];
va_list ap;
va_start(ap, fmt);
va_end(ap);
return n;
int main()
icc -c -O3 -ip -D_LARGEFILE64_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -DNO_STRERROR -DNO_vsnprintf ztest4124.c
=== ztest4124.c ===
int main()
return 0;
ALL = static all64
AR = ar
ARFLAGS = rc
CC = icc
CPP = icc -E
EXE =
LDCONFIG = ldconfig
LDFLAGS =
LDSHARED = icc
LDSHAREDLIBC = -lc
RANLIB = ranlib
SHAREDLIB =
SHAREDLIBM =
SHAREDLIBV =
STATICLIB = libz.a
VER = 1.2.8
Z_U4 =
uname = Linux
Apparently, you are asking icc to link a C++ application. icc and icpc mirror the distinction between gcc and g++, with only the C++ compiler having built-in ability to find C++ libraries. The feature of over-riding selection of a C compiler by specifying a .CC or .cpp input file doesn't survive to the link stage.
You do need a fully functional g++ on path so that icpc can use libraries including libstdc++.
The comments make it appear that you specified something like CC = icc without equivalent C++ define, such as CXX = icpc. I suppose the suggestion of dropping CC may cause it to choose gcc and g++, which would be OK. There isn't necessarily any advantage to use of icpc for such an application, as the libraries built by g++ must work with icpc as well.
Apart from whatever Tim pointed out, I am also guessing that this is an issue with *NON-AVAILABILITY* of static libc? because i see these messages :-
Since there are no shared libs support, its switching to use static libs.
So you may also give a try by installing the static libc and including the path in library path and build again.
Sukruth H V
Hello Tim and Sukruth,
Many thanks for your prompt response. I did what Tim told me . I set on my BASH shell export CXX=icpc and then proceeded to type ./configure --prefix=/usr/local/
and then I see the script runs just fine. However it runs the gcc version of the code. I presume that is OK because I have a long way ahead. I need to build HDF5, then NetCDF4, NetCDF-fortran, Jasper, PNG, WRF(Weather Research Forecasting), WPS and then finally WRFDA. Any mistake at this stage would be very costly exercise later on. If by setting CXX=icpc gcc compiles zlib pray may I ask did I do the do right thing by installing icc and icpc ? Because what I really want is to compile WRF with icc and ifort and NOT gcc and gfortran
Sukruth - I do not know how to install static libc. Please guide me accordingly or provide a URL.
Please advise me accordingly.
Ashwin.
Hi Ashwin,
Sorry i had missed to provide a link to the article describing the workarounds, Please refer to this doc :-
https://software.intel.com/en-us/articles/error-ld-cannot-find-lm/ ;
However if you are using Ubuntu, then you may try this command to install the libs :- "apt-get install build-essential"
Sukruth H V
Hi Sukruth,
That works just fine i.e. the ubuntu update. But it is still using gcc to build zlib. Is that OK ? I tried to build JASPER by setting export CC=icc. Again got a whole bunch of configure errors. I want to be clear one more time. My goal is to build WRF and WPS and WRFDA with icc and ifort NOT gcc and gfortran. Why ? Because I have some NETCDF errors with gfortran I am unable to fix.
So it is absolutely crucial that I build with icc and ifort. If we are going to do this route of mixed libraries i.e. compiling some with gcc and some others with icc and ifort I hope things will turn out OK in the end.
Ashwin.
I am trying to use the same thread to my total build errors. Please let me know if I need to open a separate thread for every library that I am building.
This is with libpng and setting CC=icc.
This is the log that I have when I type make.
libtool: link: icc -g -O2 -o .libs/pngfix contrib/tools/pngfix.o ./.libs/libpng16.so -lm -lz
ld: warning: libimf.so, needed by ./.libs/libpng16.so, not found (try using -rpath or -rpath-link)
ld: warning: libsvml.so, needed by ./.libs/libpng16.so, not found (try using -rpath or -rpath-link)
ld: warning: libirng.so, needed by ./.libs/libpng16.so, not found (try using -rpath or -rpath-link)
ld: warning: libintlc.so.5, needed by ./.libs/libpng16.so, not found (try using -rpath or -rpath-link)
ld: .libs/pngfix: hidden symbol `__intel_cpu_feature_indicator' in /opt/intel/composer_xe_2013_sp1.3.174/compiler/lib/intel64/libirc.a(cpu_feature_disp.o) is referenced by DSO
ld: final link failed: Bad value
make[1]: *** [pngfix] Error 1
make[1]: Leaving directory `/home/aswin/meteorology_project/libpng-1.6.12'
make: *** [all] Error 2
If that build script uses the typical scheme of CC and CXX to choose C and C++ compilers, you should be able to set CC=icc CXX=icpc
The link errors would be caused by building objects with icpc but then attempting to use g++ to link, as g++ and ld themselves aren't aware of the libraries provided with icpc.
