Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Unable to compile by Intel Compiler MFC project in Microsoft Visual Studio 2019
I am trying to compile my MFC project in Microsoft Visual Studio 2019. Intel Parallel studio 2020 is used (Compiler 19.1).
I am getting error - unable to obtain mapped memory (see pch_diag.txt) in all configurations(x86/x64/Release/Debug).
Known workaround (compiler key /Qoption,cpp,--pch_control=60000000 ) isn't work.
Tags (1)
Highlighted
Community Manager
Hi Dmitry,
Thank you for posting in Intel C++ compiler forum. Could you share us with the following details to reproduce the issue from our end.
1. Details about the application
2. Error log and
3. Steps to reproduce
Gopika
Highlighted
Hi Gopika,
Thanks for your attention. The attachment includes  files with compiler's logs and an archived test project. An error appears during building. All  settings are default.
Cordially yours,
Dmitry
Highlighted
Community Manager
Hi Dmitry
Thank you for sharing the details. We tried building the MFC_Intel_test.cpp from our end. It built successfully. We were unable to reproduce the issue. After reading the thread :- https://community.intel.com/t5/Intel-C-Compiler/error-unable-to-obtain-mapped-memory-see-pch-diag-tx...
The error is due to an implementation restriction in the Intel precompiled headers. When the Intel compiler restores precompiled headers (the /Yu option) it needs to obtain a big chunk of memory at a particular address. If that chunk of memory is being used by a different process then you will see that message.
We’ve seen that you already tried a workaround and it didn’t work :
Please try removing the precompiled headers and try again.
( https://community.intel.com/t5/Intel-C-Compiler/Intel-C-16-0-Error-Unable-to-Obtain-mapped-memory-se... )
We’re forwarding this issue to the concerned internal team who can help you out.
Gopika
Highlighted
What Visual Studio 2019 version are you using? And what IPSXE2020 Update version?
Can you see how pch.cpp was compiled? then create a preprocess file for us to investigate?
Highlighted
Microsoft Visual Studio Professional 2019 Version 16.6.5
Intel® C++ Compiler – extension version 19.1.0.16, Package ID: w_comp_lib_2020.2.254
Highlighted
1>------ Build started: Project: MFC_Intel_test, Configuration: Release x64 ------
1>pch.cpp
1>C:\Program Files (x86)\Windows Kits\10\Include\10.0.19041.0\shared\d3d9types.h(182): error : unable to obtain mapped memory (see pch_diag.txt)
1> D3DLIGHT_SPOT = 2,
1> ^
1>
1>compilation aborted for pch.cpp (code 4)
1>Done building project "MFC_Intel_test.vcxproj" -- FAILED.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Highlighted
Can you upgrade the compiler to IPSXE2020 Update 4 to see if it solves your issue? if not, can you give us pch.i file?
Highlighted
Ok. I'm starting to download trial version of to IPSXE2020 Update 4  rigth now. Please expect results on Monday (may be).
Highlighted
Or better to download and use the C++ Compiler Classic in https://software.intel.com/content/www/us/en/develop/tools/oneapi/hpc-toolkit.html
Highlighted
Problem still exists.
Intel® C++ Compiler – extension version 19.1.0.16, Package ID: w_comp_lib_2020.4.311.
Zipped ipch file is attachment.
Highlighted
What is the attached file? is it a preprocess file of pch.cpp? I can't compile the file you attached.
Just to make sure, is this a compiler version you have:
C:\Programs Files (x86)\IntelSWTools> icl
Intel(R) C++ Intel (R) 64 Compiler for applications running on Intel(R), Version 19.1.3.311 Build 20201010_000000
Highlighted
@Viet_H_Intel wrote:
...if not, can you give us pch.i file?
It depends what you mean by "pch.i file". I can't find it in MSVS project structure.
I had sent *.iphc file.
This is the only one that looks like a "pch.i file" from your request.
Highlighted
From your output.txt, you have a compilation aborted for pch.cpp, but we couldn't reproduce it with your zip file.
Can you look into your buildlog to see how pch.cpp was compiled? then replace /C with /E, run it from the command line and send us the output. That is the preprocess file of pch.cpp?
Highlighted
Ok. Requested files is attached.
Highlighted
Normally I should be able to compile from the preprocess file, but I got so many errors with your attached file.
C:\temp>icl test.cpp /C /w
test.cpp(1744): error: expected an expression
test.cpp(1744): error: expected a ">"
test.cpp(2437): error #1292: unknown attribute "no_init_all"
  typedef struct __declspec(align(16)) __declspec(no_init_all) _CONTEXT {
I've attached your Output_with_E_key.txt (after clean up), can you try to see if you can compile from the command line?
What are the compiler options you use?
Highlighted
I don't use command line compilation. I'm interested in integration Intel's compiler in my MSVC projects for AI. I had add test.cpp in my project and had compiled only that file.
1>pch.cpp
1>compilation aborted for pch.cpp (code -1073741571)
1>C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\MSBuild\Microsoft\VC\v160\Platforms\x64\PlatformToolsets\Intel C++ Compiler 19.1\Toolset.targets(198,5): error MSB6006: "icl.exe" exited with code -1073741571.
Keys for compilation were default:
/Yu"pch.h" /GS /W3 /Gy /Zc:wchar_t /Zi /O2 /Fd"x64\Release\vc142.pdb" /Zc:inline /fp:precise /D "_WINDOWS" /D "NDEBUG" /D "_UNICODE" /D "UNICODE" /D "_AFXDLL" /Qipo /Zc:forScope /Oi /MD /FC /Fa"x64\Release\" /EHsc /nologo /Fo"x64\Release\" /Qprof-dir "x64\Release\" /Fp"x64\Release\MFC_Intel_test.pch"
If you provide to me some scripts for command line compilation, i will run them with my pleasure.
Highlighted
From VS:
Project->Properties->C/C++->All Options.
On the right panel, Edit "Additional Options with /E", scroll down and select "Yes /P" for Preprocess to a File. Click Apply and OK
Build->Clean Solution, Build->Compile
You should see a same_source_file_name.i file under project_name/Release folder.
Please provide us that .i file.
Highlighted
Unfortunately I can't find any *.i files in project structure. May by your mean *.log file? I had attached zipped project after making all yours advises.
Highlighted
yes, that test.log is the one I wanted.
However, I couldn't reproduce the error that you saw with VS and command line using your test.cpp (test.log)
icl test.cpp /c /w /GS /Gy /Zc:wchar_t /Zi /O2 /Zc:inline /fp:precise /Qipo /Zc:forScope /Oi /MD /FC
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.3.311 Build 20201010_000000
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
test.cpp
dir test.*
 Volume in drive C is IntelBuild
 Volume Serial Number is 3604-F065
11/23/2020 04:25 AM     8,912,411 test.cpp
11/23/2020 04:58 AM    14,261,215 test.obj
Can you: Start->Intel Parallel Studio XE 2020 -> Compiler 19.1 for Intel64 to open a command Window and run:
test.cpp is attached.
