I am unable to compile the following c++ code.
#include <iostream> int main () { std::cout<<"Hello world !" <<std::endl ; return 0 ; }
gcc version 8.0.1 20180131
icpc version 18.0.1
Compilation Error :
icpc hello.cpp
In file included from /usr/include/c++/8/bits/move.h(55),
from /usr/include/c++/8/bits/nested_exception.h(40),
from /usr/include/c++/8/exception(144),
from /usr/include/c++/8/ios(39),
from /usr/include/c++/8/ostream(38),
from /usr/include/c++/8/iostream(39),
from hello.cpp(1):
/usr/include/c++/8/type_traits(1061): error: type name is not allowed
: public __bool_constant<__is_assignable(_Tp, _Up)>
from hello.cpp(1):
from hello.cpp(1):
/usr/include/c++/8/type_traits(1061): error: identifier "__is_assignable" is undefined
compilation aborted for hello.cpp (code 2)
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Seems like GCC version you have installed isn't supported by ICC 18.0.
Viet
if you add the "-ansi" option, it will compile.
Jean-Charles
Thanks. That actually worked.
You need to install the GCC version is not supported by ICC 18.0. You can download the supported GCC version from rocketmail tech support. Then, you can run any C++ code to that supported GCC without compilation error.
full codes
