Intel® C++ Compiler
Unable to create a templated function pointer to std::max
Levi_Morrison
The following code will not compile with icpc 15.0.2:
#include <algorithm>
#include <array>
#include <numeric>
template<typename T>
T const & (*maxer) (T const &, T const &) = std::max<T>;
int main(void) {
    std::array<float, 8> data;
    std::iota(data.begin(), data.end(), 0.0f);
    if (std::accumulate(data.begin(), data.end(), 0.0f, maxer<float>) == 7.0f) {
        return 0;
    } else {
        return 1;
Here is the output:
$ icpc -std=c++14 -Wall -Wextra max.cc
max.cc(6): error: "maxer" is not a function or static data member
max.cc(11): error: identifier "maxer" is undefined
max.cc(11): error: type name is not allowed
max.cc(11): error: expected an expression
compilation aborted for max.cc (code 2)
This code compiles successfully under clang++ and g++. As far as I can tell it is completely standards complaint. I suspect this is just a bug. I can work around it in the meantime by removing the template and hard-coding a type.
KitturGanesh
Hi Levi,
Yes, this is indeed a bug and thanks for catching this issue. I've filed with the developers and will update you as soon as the release with the fix is out. Appreciate your patience till then
_Kittur
Levi_Morrison
Thank you for the prompt reply! In this particular case the work-around is trivial but inconvenient since you have to forward declare every type you intend to use. Looking forward to the fix.
Judith_W_Intel
You are trying to use the new c++14 feature variable templates which according to this table in not yet support in the Intel 15.0 (or 16.0) compiler:
https://software.intel.com/en-us/articles/c14-features-supported-by-intel-c-compiler
GNU just added support for this in their latest release. Glad to hear you have a workaround.
Judy
Levi_Morrison
Thank you for the update. Are variable templates on the roadmap at all?
KitturGanesh
Hi Levi,
Thanks to Judy I just realized the support for variable template isn't there in the present version or in the upcoming 16.0 as well :(
I'll keep you updated as soon as the release with the support for this feature is out.
_Kittur
KitturGanesh
Yes the 5.X (I tried 5.2) release (GNU) has this support (added recently) as Judy mentioned earlier.
_Kittur
