% icc -v
Version 10.1
% icc -IPF-fma -S zfft1d.c
% grep fma zfft1d.s
zfft1d.s zfft1d.s-fma zfft1d.s-nofma
% grep fma zfft1d.s | head
// mark_description "-IPF-fma -S";
(p15)fma.s1 f13=f7,f32,f0 //6: {286:5} 263
(p15)fma.s1 f9=f14,f14,f35 //10: {286:5} 266
(p15)fma.s1 f10=f14,f13,f13 //10: {286:5} 265
(p15)fma.s1 f32=f9,f10,f10 //14: {286:5} 267
(p12)fma.s1 f7=f6,f12,f0 //15: {285:5} 290
(p12)fma.s1 f33=f8,f8,f34 //19: {285:5} 293
(p12)fma.s1 f6=f8,f7,f7 //19: {285:5} 292
(p12)fma.s1 f12=f33,f6,f6 //23: {285:5} 294
fma.d.s1 f9=f10,f1,f0 //10: {313:5} 1009
What is the best way to disable generation of FMA instructions?
I don't think we could know what is best for you, but you might try looking at the docs.
People who haven't tried it tend to claim that fma will always yield big increases in performance (much more than what you are likely to see if you actually test it).
Since I was doinga grep for fma in the assembly file with and without this option, I figured it was not being disabled. After seeing your explanation I see that I see what is happening. Thanks!
The basic code is:
do 30 k=1,n
do 20 j=1,n
do 10 i=1,n
a(i,k)=a(i,k)+b(i,j)*c(j,k)
10 continue
20 continue
30 continue
My session window is:
pople4700% ifort -no-IPF-fma -o mxm-nofma mxm_omp.f
pople4700% ifort -IPF-fma -o mxm-fma mxm_omp.f
pople4700%
pople4700% ./mxm-fma
mulijk - n= 1024 a(1,1) = 2048.00 elapsed = 1.38590 rate = 1549.52
pople4700%
pople4700% ./mxm-nofma
mulijk - n= 1024 a(1,1) = 2048.00 elapsed = 1.38420 rate = 1551.43
pople4700%
Any suggestions on how I can best to verify the impact of FMA? I can include the entire code (it is fairly trivial) if you want to replicate this exact problem.
Thanks!
