Intel® C++ Compiler
7833 Discussions
Unable to download Intel C++ Composer XE 2011 Update 11 Issue Status: New - Under Review
Michela_V_
I am looking to install on Windows Intel FORTRAN Composer 2011 Update 11 and Intel C++ Composer XE 2011 Update 11. I registered for a 30 days trial of Intel Parallel Studio. Since I need the 2011 release I followed the instruction in the following link: https://software.intel.com/en-us/articles/older-version-product. I accessed the Intel® Registration Center and successfully installed the Composer Edition for Fortran. However I cannot see the C++ one in the registration center, it appears there is only the one for Linux. I would appreciate some help on this.
I was trying to solve this issue trhorugh the Premium Support, but since this morning I get an error message when trying to log into the portal.
Yuan_C_Intel
Hi, Michela
Can you login and access below download link for Intel® Parallel Studio XE Composer Edition for C++ Windows*:
https://registrationcenter.intel.com/en/products/download/2954/
There's version for 2011 available.
SergeyKostrov
Valued Contributor II
>>Can you login and access below download link for Intel® Parallel Studio XE Composer Edition >>for C++ Windows*: >>https://registrationcenter.intel.com/en/products/download/2954/ Thank you, Chen! I've been using 2011 version update 12 since 2012 and I will try to install update 13. Even if it is old version I still use it for verification of compatibility some C/C++ codes with modern C++ compilers. PS: I use even older versions, like Intel C++ compiler versions 7.x and 8.x, updated to their last updates.
bosken__yuliana
Hi
I am trying to download the Intel Parallel Studio Package for Linux. I tried on my windows computer using Ghrome and after a while I get a message The Site can't be reached. I tried to get it directly on my Linux box 'wget...' but I get connection timed out.
I have activated a license for the linux machine and I am not sure if I am doing something wrong or intel website is the problem.
Thank you
