The same issue has also been posted on WSL repository: https://github.com/Microsoft/WSL/issues/3231
* Your Windows build number: Microsoft Windows [version 10.0.17134.48]
A simple test program provided along with Intel MPI is used.
#include "mpi.h" #include <stdio.h> #include <string.h> int main (int argc, char *argv[]) { int i, rank, size, namelen; char name[MPI_MAX_PROCESSOR_NAME]; MPI_Status stat; MPI_Init (&argc, &argv); MPI_Comm_size (MPI_COMM_WORLD, &size); MPI_Comm_rank (MPI_COMM_WORLD, &rank); MPI_Get_processor_name (name, &namelen); if (rank == 0) { printf ("Hello world: rank %d of %d running on %s\n", rank, size, name); for (i = 1; i < size; i++) { MPI_Recv (&rank, 1, MPI_INT, i, 1, MPI_COMM_WORLD, &stat); MPI_Recv (&size, 1, MPI_INT, i, 1, MPI_COMM_WORLD, &stat); MPI_Recv (&namelen, 1, MPI_INT, i, 1, MPI_COMM_WORLD, &stat); MPI_Recv (name, namelen + 1, MPI_CHAR, i, 1, MPI_COMM_WORLD, &stat); printf ("Hello world: rank %d of %d running on %s\n", rank, size, name); } } else { MPI_Send (&rank, 1, MPI_INT, 0, 1, MPI_COMM_WORLD); MPI_Send (&size, 1, MPI_INT, 0, 1, MPI_COMM_WORLD); MPI_Send (&namelen, 1, MPI_INT, 0, 1, MPI_COMM_WORLD); MPI_Send (name, namelen + 1, MPI_CHAR, 0, 1, MPI_COMM_WORLD); } MPI_Finalize (); return (0); }
Compiling and executing with OpenMPI (installed via `apt install`, 1.10.2) raise no issues.
mpicc test.c; mpirun -np 4 ./a.out Hello world: rank 0 of 4 running on tianyi Hello world: rank 1 of 4 running on tianyi Hello world: rank 2 of 4 running on tianyi Hello world: rank 3 of 4 running on tianyi
However using Intel MPI (`compilers_and_libraries_2017.7.259`, before running I uninstalled OpenMPI to prevent possible include/lib conflits) I got the following error
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 1734 RUNNING AT tianyi = EXIT CODE: 139 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 1734 RUNNING AT tianyi = EXIT CODE: 11 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== Intel(R) MPI Library troubleshooting guide: https://software.intel.com/node/561764 ===================================================================================
Using `mpiicc` gives the same result. Occasionally I could also get this
[proxy:0:0@tianyi] HYDU_sock_write (../../utils/sock/sock.c:418): write error (Broken pipe) [proxy:0:0@tianyi] send_cmd_downstream (../../pm/pmiserv/pmip_pmi_v1.c:146): error writing PMI line [proxy:0:0@tianyi] fn_get_my_kvsname (../../pm/pmiserv/pmip_pmi_v1.c:491): error sending PMI response [proxy:0:0@tianyi] pmi_cb (../../pm/pmiserv/pmip_cb.c:822): PMI handler returned error [proxy:0:0@tianyi] HYDT_dmxu_poll_wait_for_event (../../tools/demux/demux_poll.c:76): callback returned error status [proxy:0:0@tianyi] main (../../pm/pmiserv/pmip.c:558): demux engine error waiting for event [mpiexec@tianyi] control_cb (../../pm/pmiserv/pmiserv_cb.c:798): connection to proxy 0 at host tianyi failed [mpiexec@tianyi] HYDT_dmxu_poll_wait_for_event (../../tools/demux/demux_poll.c:76): callback returned error status [mpiexec@tianyi] HYD_pmci_wait_for_completion (../../pm/pmiserv/pmiserv_pmci.c:501): error waiting for event [mpiexec@tianyi] main (../../ui/mpich/mpiexec.c:1147): process manager error waiting for completion
By compiling a test Fortran program, the problem appears to happen during `MPI_Init`.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
