Hello everyone,
when i try to install Intel C++ compiler 9.0 by showing it a license file *.lic, it gives the following error
Setup was unable to copy the license "*.lic". Please check that the path exists and you have an adequate permission to perform the operation.
I have the administrator privileges and path is correct, that is, everything seems to be correct, what can be wrong with this setup? Could you please help me solving the problem ?
Sincerely
Cem DEMiRKIR
Sincerely
Cem DEMiRKIR
Did you provide the full name with mylicense.lic?
Yes, I provide the full name through the Browse button.
Try this.
1. copy the license file manually to C:Program FilesCommon FilesIntelLicenses directory
2. set an env "INTEL_LICENSE_FILE=C:Program FilesCommon FilesIntelLicenses" for your system: from "my computer"->"property">"advanced"->"environment variables".
3. close the browser window, reopen it; reinstall the compiler
Jennifer
Thanks a lot Jennifer, It works smoothtly.
Sincerely
Cem DEMiRKIR
Sincerely
Cem DEMiRKIR
