I am trying to install icc v.7.1.031 under
Slackware 9.1 (kernel 2.4.22, gcc 3.2.3,
glibc 2.3.2).
I get the following response to the
interactive dialog
What rpm install options would you like? [-U --replacefiles]
-ivh --nodeps
Substitute Headers for Intel C++ Compiler for 32-bit applications, Version 7.1
Installing...
./install: line 577: 1707 Segmentation fault rpm $OPTIONS $PREFIX $CHOSENRPM >&$TEMPFILE.rpmout
Preparing... ##################################################
Installation failed.
and a similar result if I try and install directly
(using rpm) from the command line.
I didn't have this problem before: I was able to install
an earlier version of the compiler (with gcc 3.2.3 and glibc 2.3.1).
Can anyone suggest the likely cause of the segfault and how to fix it?
Many thanks,
Roger Young
r.young@irl.cri.nz
glibc 2.3.2).
interactive dialog
-ivh --nodeps
Installing...
Many thanks,
Roger Young
r.young@irl.cri.nz
The problem is with the version of rpm (4.0.2).
With rpm v.4.2.1 icc installs without difficulty.
