Intel® C++ Compiler
7839 Discussions
Unable to install XE 2016 on Ubuntu 14.04
Zhihao_Y_
Just a "Something wrong with package", nothing else.  Tried offline install, same thing.
This is a DigitalOcean instance.
Yuan_C_Intel
Hi, Zhihao
Did you use "root" or sudo to install the package? It is a possible an executable permission issue.
Zhihao_Y_
Yolanda Chen (Intel) wrote:
Did you use "root" or sudo to install the package? It is a possible an executable permission issue..
Yes I did.  No, it's not.
I can provide log the installer createed under /tmp actually, but I'm not sure about whether these logs contains sensitive information about my server.
Yuan_C_Intel
Hi, Zhihao
Could you send your installation log to me through private message? We will keep it confidential.
