I'm having troubles using SSE intrinsics in my project although everything is included.
I'm doing something like this :
I'm using Visual Studio 2008 in combination with the Intel Compiler (no clue what version, the one that came with Parallel Composer 2011 ) .
I'm sure that I enabled the /arch:SSE2 compiler flag.
I actually want to include but that generates (only by including) over 100 errors, all more or less the same than the one above.
any help with this ?
cheers
[cpp]#include "stdlib.h" #include "emmintrin.h" void Foo::Bar() { const __m128 rmul1 = _mm_set_ps1(.393f); }[/cpp]but it generates this error :
[bash]1>Foo.cpp 1>.\Foo.cpp(41): error: identifier "__m128" is undefined 1> const __m128 rmul1 = _mm_set_ps1(.393f);[/bash]the funny part is, in other parts of my project I can use whatever intrinsic I need by including the same headers and it all works fine...
cheers
Add "Preprocess to a file (/P)" to your compilation settings and compile to generate a .i file. This should contain #line comments to tell you what headers code is coming from. Do that with a known good file and see where __m128 is defined when you include emmintrin.h, then do it with a file with the error and see where it's missing the define. That should give you a clue about what's wrong.
