Hello everyone, I would like to report a bug in the Intel C++ compiler regarding alias templates.
I am attaching a MWE consisting of the following files:
// RFASolver.h #ifndef RFASOLVER_H #define RFASOLVER_H class BioLinearisedSolver { }; template <typename BSP> class RFALinearisedSolver { }; template <template <typename> class RFASolverPolicy, typename BioSolverPolicy> class RFASolver { public: void run(); }; #endif /* end of include guard: RFASOLVER_H */
// RFASolver.cpp #include "RFASolver.h" template <template <typename> class RFASolverPolicy, typename BioSolverPolicy> void RFASolver<RFASolverPolicy, BioSolverPolicy>::run() { } template class RFALinearisedSolver<BioLinearisedSolver>; template class RFASolver<RFALinearisedSolver, BioLinearisedSolver>;
// rfa.cpp #include "RFASolver.h" template <typename T> using RFASolverPolicy = RFALinearisedSolver<T>; int main(int argc, char* argv[]) { RFASolver<RFASolverPolicy, BioLinearisedSolver> rfaSolver; rfaSolver.run(); return 0; }
Now, this code compiles fine with g++, but with icpc version 19.0.1.144, compiling with
icpc -pedantic -std=c++14 -c RFASolver.cpp -o RFASolver.o icpc -pedantic -std=c++14 -c rfa.cpp -o rfa.o icpc -o rfa RFASolver.o rfa.o -pedantic -std=c++14
I get
rfa.cpp:(.text+0x30): undefined reference to `RFASolver<RFASolverPolicy, BioLinearisedSolver>::run()'
However, if I remove the alias template and use its value directly, as in
#include "RFASolver.h" int main(int argc, char* argv[]) { RFASolver<RFALinearisedSolver, BioLinearisedSolver> rfaSolver; rfaSolver.run(); return 0; }
it links fine, meaning the bug seems to be related to the use of an alias template.
I understand users like me cannot report bugs directly, is this correct? Can you please report this bug?
In case this matters, I am compiling on an HPC cluster based on Intel architecture. I tried two different clusters and multiple versions of icpc and the result is always the same.
- Tags:
- CC++
- Development Tools
- General Support
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Hi ,
I have tried to reproduce the issue with the files you have provided and the code ran without any errors with icpc compiler.
The icpc version i have used is icpc (ICC) 19.1 20200117. The bug might have been fixed in the latest version.
Could you provide the icpc versions you have tried with.
Prasanth
We don't find the issue in the latest version of icc . It compiled successfully.
Could you please upgrade your compiler to latest version (19.1) and confirm.
If you have any further issues, please get back to us.
Prasanth
Hi
Thanks for reporting the bug.
We are closing this thread as the issue is resolved in the latest version of compiler.
Please raise a new thread if you face any new issues.
Prasanth
Hi
Thanks for the confirmation , the issue is fixed in latest version.
Please check when the version gets updated in your systems and reach out to us if you face any issues.
Prasanth
