Intel® C++ Compiler
Undefined reference to explicitly instantiated template with template template parameter and alias template
Leoni__Massimiliano
Hello everyone, I would like to report a bug in the Intel C++ compiler regarding alias templates.
I am attaching a MWE consisting of the following files:
// RFASolver.h
#ifndef RFASOLVER_H
#define RFASOLVER_H
class BioLinearisedSolver
template <typename BSP>
class RFALinearisedSolver
template <template <typename> class RFASolverPolicy, typename BioSolverPolicy>
class RFASolver
public:
    void run();
#endif /* end of include guard: RFASOLVER_H */
// RFASolver.cpp
#include "RFASolver.h"
void RFASolver<RFASolverPolicy, BioSolverPolicy>::run()
template class RFALinearisedSolver<BioLinearisedSolver>;
template class RFASolver<RFALinearisedSolver, BioLinearisedSolver>;
// rfa.cpp
template <typename T>
using RFASolverPolicy = RFALinearisedSolver<T>;
int main(int argc, char* argv[])
    RFASolver<RFASolverPolicy, BioLinearisedSolver> rfaSolver;
    rfaSolver.run();
    return 0;
Now, this code compiles fine with g++, but with icpc version 19.0.1.144, compiling with
icpc -pedantic -std=c++14 -c RFASolver.cpp -o RFASolver.o
icpc -pedantic -std=c++14 -c rfa.cpp -o rfa.o
icpc -o rfa RFASolver.o rfa.o -pedantic -std=c++14
I get
rfa.cpp:(.text+0x30): undefined reference to `RFASolver<RFASolverPolicy, BioLinearisedSolver>::run()'
However, if I remove the alias template and use its value directly, as in
    RFASolver<RFALinearisedSolver, BioLinearisedSolver> rfaSolver;
    rfaSolver.run();
    return 0;
it links fine, meaning the bug seems to be related to the use of an alias template.
I understand users like me cannot report bugs directly, is this correct? Can you please report this bug?
In case this matters, I am compiling on an HPC cluster based on Intel architecture. I tried two different clusters and multiple versions of icpc and the result is always the same.
PrasanthD_intel
Hi ,
I have tried to reproduce the issue with the files you have provided and the code ran without any errors with icpc compiler.
The icpc version i have used is icpc (ICC) 19.1 20200117. The bug might have been fixed in the latest version.
Could you provide the icpc versions you have tried with.
Prasanth
Leoni__Massimiliano
Hello Prasanth, thanks for your reply. As I mentioned in my original post, the most recent version I was able to reproduce the problem with was version 19.0.1.144.
PrasanthD_intel
We don't find the issue in the latest version of icc . It compiled successfully.
Could you please upgrade your compiler to latest version (19.1) and confirm.
If you have any further issues, please get back to us.
Prasanth
PrasanthD_intel
Hi
Thanks for reporting the bug.
We are closing this thread as the issue is resolved in the latest version of compiler.
Please raise a new thread if you face any new issues.
Prasanth
Leoni__Massimiliano
Hello Dwadasi, I am not a sysadmin on these machines so I cannot update the compiler. If you say it is fixed in the latest version, then it's ok, go ahead and close this thread. Thanks for the help!
PrasanthD_intel
Hi
Thanks for the confirmation , the issue is fixed in latest version.
Please check when the version gets updated in your systems and reach out to us if you face any issues.
Prasanth
