When trying to compile this code:
File main.cc:
#include <iostream> namespace NS { void print(); } using namespace NS; void NS::print() { extern int a; std::cout << a << std::endl; } int main(int argc, char** argv) { NS::print(); return 0; }
File b.cc:
namespace NS { int a = 3; }
I find that the icpc emits undefined references to the symbol 'a' while GCC and Clang compile and link without problems. This is on Linux x86_64 using ICC version 16.0.3 with GCC 4.9 as backend.
g++ -o gcc_main.o -c main.cc
g++ -o gcc_b.o -c b.cc
g++ -o gcc_extern gcc_main.o gcc_b.o
icpc -o icc_main.o -c main.cc
icpc -o icc_b.o -c b.cc
icpc -o icc_extern icc_main.o icc_b.o
icc_main.o: In function `main':
main.cc:(.text+0x2d): undefined reference to `a'
icc_main.o: In function `NS::print()':
main.cc:(.text+0x58): undefined reference to `a'
It looks like icpc emits an unresolved symbol for "a" into main.o while g++ puts "NS::a" into main.o as unresolved. The latter is then available at link time but the former is not.
Thanks for your help
Bastian
We believe this is in violation with the C++ standard:
http://www.open-std.org/JTC1/SC22/WG21/docs/papers/2011/n3242.pdf
The enclosing namespaces of a declaration are those namespaces in which the declaration lexically appears, except for a redeclaration of a namespace member outside its original namespace (e.g., a definition as specified in 7.3.1.2). Such a redeclaration has the same enclosing namespaces as the original declaration.
[Example: § 7.3.1 159 c ISO/IEC N3242=11-0012
namespace Q {
namespace V {
void f(); // enclosing namespaces are the global namespace, Q, and Q::V
class C {
void m();
void V::f() { // enclosing namespaces are the global namespace, Q, and Q::V
extern void h(); // ... so this declares Q::V::h
void V::C::m() {
— end example ]
Yes I agree with you. I've created DPD200411955 in our internal bugs database.
Thanks for reporting this problem.--Melanie
This issue has been fixed in the latest 16.0 compiler update. FYI.
