I am compiling an old project with Composer X 2013 U1 on a Mac. It compiles and links fine but I am compiling on Mac OS X 10.7 and I would like the app to be compatible with Mac OS X 10.6 too. So I add this argument: -mmacosx-version-min=10.6 When I do it, the linkier fails:
Undefined symbols for architecture x86_64: "_main", referenced from: start in crt1.10.6.o
ld: symbol(s) not found for architecture x86_64
I guess I will have to add some special library to the linker?
I can't reproduce the error on my OS X 10.7. See below. Could you please provide more details, including a simple test case and command line?
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.1.119 Build 20121010
Copyright (C) 1985-2012 Intel Corporation. All rights reserved.
$ icc a.c -mmacosx-version-min=10.6
$ icc a.c
Thank you.
Feilong H.
Intel Developer Support
Tools Knowledge Base: http://software.intel.com/en-us/articles/tools
BTW, my OS X version is
$ sw_vers -productVersion
10.7.5
When I run the following, it works fine:
icc -I../../include -O0 -fmath-errno -fp-model precise -fno-omit-frame-pointer -g -fPIC -fvisibility=hidden -pthread -openmp -mmacosx-version-min=10.6 -DFL_LTL_ENDIAN -DFL_MACI64 -o /.............../myfile.o -c myfile.c
But I get the error when I run this:
icc -dynamiclib -framework Foundation -mmacosx-version-min=10.6 -L/.................. -fmath-errno -fp-model precise -g -fPIC -fvisibility=hidden -fno-omit-frame-pointer -pthread -openmp -o /......./libmyfile.dylib /......./myfile.o
When I run sw_vers -productVersion I get 10.7.5 and when I run icc -V I get Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.1.119 Build 20121010 so it seems that we have same versions.
Thanks for the command lines. Unfortunately, I still failed to reproduce the error with a simple file. Could you please upload a small test case?
$ icc -O0 -fmath-errno -fp-model precise -fno-omit-frame-pointer -g -fPIC -fvisibility=hidden -pthread -openmp -mmacosx-version-min=10.6 -c a.c
$ icc -dynamiclib -framework Foundation -mmacosx-version-min=10.6 -fmath-errno -fp-model precise -g -fPIC -fvisibility=hidden -fno-omit-frame-pointer -pthread -openmp -o a.dylib a.o
