Hi
This standalone example illustrates my problem:
#include <iostream> int main() { double x = 1.2e-154; double y = 6.0e-156; x *= y; std::cout << x << std::endl; }
Compiling with both MSVC11 and Intel 16.0 update 1, 64bit release with /fp:precise and (for Intel) /Qftz is NOT set.
Output:
$ ./ftz_msvc11.exe 7.2e-310 $ ./ftz_icpc16.exe 0
Same thing on linux, gcc returns the denormal, icpc returns zero.
So it seems that the Intel code is flushing the denormal even though I haven't actually asked it to. Is this expected behaviour? The full command line is
/GS /W3 /Gy /Zc:wchar_t /Zi /O2 /Fd"x64\Release\vc110.pdb" /fp:precise /D "__INTEL_COMPILER=1600" /D "WIN32" /D "NDEBUG" /D "_CONSOLE" /D "_UNICODE" /D "UNICODE" /Qipo /Zc:forScope /Oi /MD /Fa"x64\Release\" /EHsc /nologo /Fo"x64\Release\" /Qprof-dir "x64\Release\" /Fp"x64\Release\ftz.pch"
Many thanks,
Andrew
I have tried to reproduce your issue using a x64 Windows* system with ICL 16.0 update I and VS 11 as specified in your post. I have used your code sample (thanks). However, I have not been able to reproduce it. See below:
icl /GS /W3 /Gy /Zc:wchar_t /Zi /O2 /fp:precise /D "__ INTEL_COMPILER=1600" /D "WIN32" /D "NDEBUG" /D "_CONSOLE" /D "_UNICODE" /D "UNIC ODE" /Qipo /Zc:forScope /Oi /MD /EHsc /nologo test.cpp test.cpp ipo: remark #11001: performing single-file optimizations ipo: remark #11074: Inlining inhibited by limit max-size ipo: remark #11074: Inlining inhibited by limit max-total-size ipo: remark #11075: To get full report use -Qopt-report:4 -Qopt-report-phase ipo ipo: remark #11006: generating object file C:\Temp\3\ipo_1320811.obj $test.exe 7.2e-310
I have used a command line. Did you use a command line as well or did you run it from within VS?
Noga
Intel Developer Support
Qftz is included in icl default fp:fast while in gcc the usual way to get it is -ffast-math. This is among the similarities between fp:fast and fast-math.
Beginning with introduction of avx, intel CPU shouldn't incur a performance penalty for additions involving denormal. This improvement seems to have been intended to deal with usual gcc practice. Multiplication still may require ftz for full performance.
I haven't heard of anyone changing practices regarding ftz usage to take advantage of current CPU.
When Windows x64 was introduced, we were informed that the os would set ftz prior to starting a user task. Apparently, this has changed.
Thanks for looking into it Noga
It's odd that you cant replicate it given I immediately got the same on a completely different machine, so here's the simplest way I've found for recreating the issue (this time on linux, source as per original post). Note no optimisation now. Be grateful for confirmation if anyone can/can't replicate this
blah@blah:~/dev/ftz $ g++ ftz.cpp -o gcc;./gcc 7.2e-310 blah@blah:~/dev/ftz $ icpc ftz.cpp -o icc;./icc 0 blah@blah:~/dev/ftz $ g++ --version g++ (GCC) 4.9.3 Copyright (C) 2015 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. blah@blah:~/dev/ftz $ icpc --version icpc (ICC) 16.0.1 20151021 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. blah@blah:~/dev/ftz $ cat /proc/cpuinfo | grep "model name" | tail -1 model name : Intel(R) Xeon(R) CPU E7- 4870 @ 2.40GHz
PS. I originally encountered the issue on a Xeon E5-1650, for what it's worth.
Andrew
...or you could use this code. Which emphasises that the multiplication is flushing (and that DAZ is not enabled for that matter)
#include <iostream> int main() { double x = 1.2e-154; double y = 6.0e-156; double z = 7.2e-310; //=x*y std::cout << x * y << std::endl; std::cout << z << std::endl; } blah@blah:~/dev/ftz $ icpc ftz.cpp -o icc;./icc 0 7.2e-310
Update, having read Tim's comment realised was missing -fp-model precise, and indeed now it's not doing FTZ (unless I explicitly use -ftz).
So the question now is why was the original Windows version seemingly ignoring the /fp:precise flag. In answer to Noga, yes I was using the IDE , and the command line I posted was from the project settings dialog.
I will look into it to see if their is an issue with the IDE integration.
Noga
Hi Noga,
Yes I can confirm it's the IDE - command line compilation behaves as expected. Looking at one of the generated log files I see the following:
$ cat icl.command.1.tlog ¦¦^ E : \ D E V \ T E S T \ F T Z \ F T Z \ S O U R C E . C P P / c / Q m 6 4 / Z i / n o l o g o / W a l l / O 2 / O i / Q i p o / Q f t z / D _ _ I N T E L _ C O M P I L E R = 1 6 0 0 / D W I N 3 2 / D N D E B U G / D _ C O N S O L E / D _ U N I C O D E / D U N I C O D E / E H s c / M D / G S / G y / f p : p r e c i s e / Q o f f l o a d - o p t i o n , m i c , c o m p i l e r , " " / Z c : w c h a r _ t / Z c : f o r S c o p e / F o " X 6 4 \ R E L E A S E \ \ " / F d " X 6 4 \ R E L E A S E \ V C 1 1 0 . P D B " / T P E : \ D E V \ T E S T \ F T Z \ F T Z \ S O U R C E . C P P
...which looks incorrect, specifically it contains /Qftz.
Andrew
Hi Andrew,
I have checked your code sample within VS and was able to duplicate your original issue. It seems that indeed we have an issue with the IDE integration. I have escalated it to our engineers [DPD200379834]. Thank you again for flagging this issue.
Noga
Thanks Noga,
While this is being fixed do you have any suggestion on a possible workaround? Sadly, due to the size of our codebase (~3M lines) switching to command-line compilation is not a realistic option.
Andrew
Hi Andrew,
In Properties --> Command Line, add "/Qftz-" in Additional Options to ensure FTZ is not utilized.
Noga
Thanks Noga, that works
This issue had been fixed in the 2016 Update 3 compiler
