Hello.
I'm using Composer XE 2013 SP1 (version: 14.0.0 20130728).
I got an error, while compiling this code:
#include <tuple>
#include <memory>
int main()
auto a = std::make_tuple(std::unique_ptr<char>(new char), 0);
return 0;
Command line and comiper output is here:
icpc tmp.cpp -gcc-name=gcc-4.7 -std=gnu++11 -lstdc++
/usr/include/c++/4.7/type_traits(1251): error: function "std::unique_ptr<_Tp, _Dp>::unique_ptr(const std::unique_ptr<_Tp, _Dp> &) [with _Tp=char, _Dp=std::default_delete<char>]" (declared at line 262 of "/usr/include/c++/4.7/bits/unique_ptr.h") cannot be referenced -- it is a deleted function
static decltype(__test_aux<_To1>(std::declval<_From1>()), __one())
detected during:
instantiation of "std::__is_convertible_helper<_From, _To, false>::__test [with _From=const std::unique_ptr<char, std::default_delete<char>> &, _To=std::unique_ptr<char, std::default_delete<char>>]" based on template arguments <const std::unique_ptr<char, std::default_delete<char>> &, std::unique_ptr<char, std::default_delete<char>>> at line 1258
instantiation of class "std::__is_convertible_helper<_From, _To, false> [with _From=const std::unique_ptr<char, std::default_delete<char>> &, _To=std::unique_ptr<char, std::default_delete<char>>]" at line 1265
instantiation of class "std::is_convertible<_From, _To> [with _From=const std::unique_ptr<char, std::default_delete<char>> &, _To=std::unique_ptr<char, std::default_delete<char>>]" at line 117
instantiation of class "std::__and_<_B1, _B2> [with _B1=std::is_convertible<const std::unique_ptr<char, std::default_delete<char>> &, std::unique_ptr<char, std::default_delete<char>>>, _B2=std::is_convertible<const int &, int>]" at line 848 of "/usr/include/c++/4.7/tuple"
instantiation of "std::tuple<std::__decay_and_strip<_Elements>::__type...> std::make_tuple(_Elements &&...) [with _Elements=<std::unique_ptr<char, std::default_delete<char>>, int>]" at line 9 of "tmp.cpp"
compilation aborted for tmp.cpp (code 2)
If I compile this code with gcc compiler - there are no problem. What's wrong?
