Greetings,
I have searched through the forum and noticed that this topic has come up before, unfortunately without a clean solution. The problem once again is as follows:
VS2003 Compiler Debug = OK
VS2003 Compiler Release = OK
Intel C++ 9 Compiler Debug = OK
Intel C++ 9 Compiler Release = UNEXPECTED BEHAVIOUR
As some of the previous threads on this topic suggested I tried to change some of the flags in the optimization settings. Some of the unexpected behaviour actually dissapears when setting the "floating point precision improvement" to "Max(/0p)." Unfortunately it does not solve all the unexpected results. It seems that the only way to get rid of the unexpected results is to turn the "Optimizations" to "Disabled (/0d)" which ofcourse defeats the point of having a Release mode in the first place.
Any suggestions ofcourse are welcome! My system is a P4, WinXP, VS2003, Intel C++ 9.0.
Thanks in advance,
Aristotel
Thanks in advance,
Aristotel
Did you try /Ob0 plus /Op?
It sounds a bug, could you file an issue report to Premier Support?
Jennifer
Uninitialized data also could explain this.
I have looked for unitialized variables, both manually and by setting the compiler warning level to 4. So I don't think the problem is uninitialized variables this time.
I have tried to use the Premier Support but the website doesn't work, it gives a "403 Forbidden: Access Denied" message.
What is the /Ob0 flag? I cannot find it in the documentation. Only /Ob1
Aristotel
Aristotel
/Ob0 is to disable inlining. Because of it, some other optimizations may not happen. It's usually a work around to move forward. You can add "/Ob0" to the project property under "C/C++->Command Line->Additional Options".
But we still need to root cause the problem. I'll try to create an issue report at Premier Support for you.
Jennifer
