Hi ! First of all, big Kudos to Intel for supporting Educational Community !!!
I wrote small program to try out new feature in C+11 - Uniform Initialization. However, getting a lot of errors and one incorrect result.
(Basically, I am following http://www.informit.com/articles/article.aspx?p=1852519)
Using Visual Studio 2012(latest) with Intel C++ Compiler 13(latest). C++0x support enabled.
#include <iostream>
#include <string>
#include <vector>
#include <map>
using namespace std;
class C {
public:
C(int a = 1, int b = 2) : n{0,1,2,3,4}, a_{a}, b_{b} {};
int n[5];
int a_,b_;
int main()
C c = C{}; // OK
C *p = new C; // OK
//C *p2 = new C{}; // Does not compile
cout << c.a_ << " " << c.b_ << endl; // Getting "0 0" instead of "1 2"
int var{0}; // OK
string s{"hello"}; // OK
string s2{s}; // OK copy constructor
//vector<string> vs{"alpha", "betta", "gamma"}; // Does not compile
//double *pd= new double [3] {0.5, 1.2, 12.99}; // Does not compile
//int n{}; // Does not compile
//int *p{}; // Does not compile
//char s[12]{}; // Does not compile
//string s{}; // Does not compile
//char *p=new char [5]{};
return 0;
Thanks !
Please upgrade to Intel compiler 14.0... version13.0 was released well before MSVC++ 2012 existed.
When I uncomment the lines in your example and compile with 14.0 and VS 2012 I see these expected errors:
19% icl /Qstd=c++11 -c t.cpp
Intel(R) C++ Compiler XE for applications running on IA-32, Version 14.0 Beta Bu
ild x
Built Aug 15 2013 22:00:50 by jward4 on JWARD4-DESK in D:/workspaces/14_0cfe/dev
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.
t.cpp
t.cpp(27): error: no instance of constructor "std::vector<_Ty, _Alloc>::vector [
with _Ty=std::string, _Alloc=std::allocator<std::string>]" matches the argument
list
argument types are: (const char [6], const char [6], const char [6])
t.cpp(31): error: "p" has already been declared in the current scope
t.cpp(32): error: "s" has already been declared in the current scope
t.cpp(33): error: "s" has already been declared in the current scope
t.cpp(34): error: "p" has already been declared in the current scope
compilation aborted for t.cpp (code 2)
Note the first error is because the MSVC++ 2012 standard library headers do not yet have std::initializer_list constructors.
Judy
Judith, thank you for replying !!
I downloaded Beta Version 13 SP1 (I guess stable release is 13.0) and tested once again.
Most of the stuff worked fine. However, I am also getting two errors for two lines:
//double *pd= new double [3]{0.5, 1.2, 12.99}; // Does not compile
// char *p3=new char [5]{}; // Does not compile
Both produce idential error:
1>------ Build started: Project: Virtual Functions (Intel C++ 14.0), Configuration: Debug Win32 ------
1> Source.cpp
1>" : error : backend signals
1>
1> compilation aborted for Source.cpp (code 4)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
-Alexander
Alexander,
I can reproduce the internal error in our development compiler. I created a new defect report for it (DPD200247538). Thanks for reporting it to us ... it seems to be caused by aggregate initialization of array types. We will fix it as soon as possible.
thanks again,
Judy
