I wanted to rebuild existing solution to make it Universal API compliant. The story is that when I added linking to onecoreuap.lib Visual Studio returns many errors about "unresolved external symbol" to some functions I am using. Yet, I found those functions in the UniversalDDIs.xml so I guess that this API should be supported. Below you'll find the specifics:
Project A:
- Lang: C++
- Target Platform Version: 10.0.15063.0
- Configuration Type: Static Library (.lib)
- Platform Toolset: Visual Studio 2015 (v140)
- Additional Dependencies: $(WindowsSDK_LibraryPath)\$(Platform)\OneCoreUAP.lib
- Ignore Specific Default Libraries: kernel32.lib;user32.lib;gdi32.lib;winspool.lib;comdlg32.lib;advapi32.lib;shell32.lib;ole32.lib;oleaut32.lib;uuid.lib;odbc32.lib;odbccp32.lib;
- Output: ProjectA.Lib
Project B:
- Lang: C++
- Configuration Type: Dynamic Library (.dll)
- Additional Dependencies: $(WindowsSDK_LibraryPath)\$(Platform)\OneCoreUAP.lib; ProjectA.Lib
- Output: ProjectB.dll
Sample output:
When I try to build the solution I get the below errors:
Error LNK2001 unresolved external symbol __imp_PathIsRelativeA (ProjectA.lib)
Error LNK2001 unresolved external symbol __imp_PathAppendW (ProjectA.lib)
Error LNK2001 unresolved external symbol __imp_PathRemoveFileSpecA (ProjectA.lib)
These 3 funcs are part of Shlwapi.dll and I found in UniversalDDIs.xml that in UWD they are supported from api-ms-win-core-shlwapi-legacy-l1-1-0.dll
Possible solution
I'll be truly thankful if you could tell me, what am I doing wrong or what else should I do or link to to make it work :)
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
See: https://stackoverflow.com/questions/42598785/static-linking-on-windows-os
You may need to add: Shlwapi.lib
Perform a Google search for: __imp_PathFileExistsA
You will find additional information.
Jim Dempsey
Jim Dempsey
