hi
I am getting the following unresolved externs
error LNK2019: unresolved external symbol "public: __cdecl std::_Lockit::_Lockit(int)" (??0_Lockit@std@@QEAA@H@Z) referenced in function "public: void __cdecl std::_Container_base12::_Orphan_all(void)" (?_Orphan_all@_Container_base12@std@@QEAAXXZ)
1>MyExcHandler.lib(myexchandler.obj) : error LNK2001: unresolved external symbol "public: __cdecl std::_Lockit::_Lockit(int)" (??0_Lockit@std@@QEAA@H@Z)
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
https://msdn.microsoft.com/en-us/library/windows/desktop/dd406935(v=vs.85).aspx
Header: Dmoimpl.h
Library: Dmoguids.lib; Msdmo.lib
Are you missing a library on your additional libraries?
Jim Dempsey
I am using the Intel compiler for SEH many of the examples have inline assembler and I am running 64 bit code I had originally posted this problems on the CodeProject and the developer there said I was mixing Microsoft Headers with Intel .lbs when running the intel compiler can I use Microsoft headers and Microsoft .libs he pointed me to this URL https://software.intel.com/en-us/node/709060 DO I have to use intel headers and libs
What SDK are you using? The normal Parallel Studio SDK does not have its own version of the standard libraries, you should link in the Microsoft ones by default. Does SEH stand for structured exception handling?
