We're using Intel C/C++ compiler version 9.0. Our app crashes with a message that reads:
Unsupported base encoding 0x30 (0x34). Please report back to Intel. Aborted.
What does that mean?
I would definitely submit a Premier Support issue on this (https://premier.intel.com). Can you try a later compiler update to see if it's resolved there?
I did see a similar issue to this related to use of the LD_PRELOAD environment variable. Do you have that set to anything?
MADlhewitt:I did see a similar issue to this related to use of the LD_PRELOAD environment variable. Do you have that set to anything?
Yes, I do. I have LD_PRELOAD=libgcc_s.so.1. After clearing the LD_PRELOAD environment variable the problem seems to go away. Could you please explain why setting LD_PRELOAD causes such a problem?
Unfortunately, we didn't get to the bottom of that on the other issue. That other customer was also mixing incompatible libs from different OS distros. Is there a reason you need LD_PRELOAD set?
