Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7700 Discussions
Unwarranted warnings: decltype vs. NULL references
vpozdyayev
Hello.
When building a project with /Wall (ICL 12.1.4.325), I get a number of warnings on the lines of
1>.h(303): warning #327: NULL reference is not allowed
1> -> std::enable_if< sizeof...( types ) != sizeof...( unpacked_types ), tuple< decltype( f( *( types * )nullptr ) )... > >::type
While normally I'd agree with this criticism, surely it has no point for an expression inside a decltype().
Vladimir
Judith_W_Intel
I'm having a hard time reproducing this...
sptxl8-302> cat ex.cpp
class types {};
template class C {};
template void f(T);
int main() {
C c;
return 0;
sptxl8-303> icpc -std=c++11 -Wall -c ex.cpp
sptxl8-304>
Can you please provide a reproducer?
thanks
Judy
vpozdyayev
Actually, I have found more spurious warnings/remarks.
[cpp]#include class dereference { public: template< typename ptr_type > auto operator () ( ptr_type &ptr ) -> decltype( *ptr ) const { return *ptr; } }; template< typename fn_type, typename arg_type > auto app( fn_type fn, arg_type arg ) -> decltype(fn(*(arg_type*)nullptr)) { return fn( arg ); } template< typename... types > void test3( types... values ) { printf( "%d%d%dn", values... ); } int main() { int x = 123; app( dereference(), &x ); test3( 1, 2, 3 ); return 0; } [/cpp]
Command line: icl /Qstd=c++0x /Wall tests.cpp
Bad warnings:
tests.cpp(6): warning #2536: type qualifiers are meaningless here
tests.cpp(12): warning #327: NULL reference is not allowed
tests.cpp(17): remark #869: parameter "values" was never referenced
The last remark shows up in the actual project in a different context as "warning #869". I'm not sure if there is a signficant difference.
Vladimir
Judith_W_Intel
thank you... I can now reproduce the warnings and remark.
For the first warning, "type qualifiers are meaningless here" -- I believe that warningis valid.
You are declaring the late specified return type as int const (after it is instantiated) and it is meaningless. If you were trying to declare the operator() member function itself as const then the const keyword should have gone before the ->.
Anyway I will submit bug reports for the 327 warning and the 869 remark since those do look incorrect.
thanks again,
Judy
vpozdyayev
> For the first warning ...
Ah yes. Mea culpa. Although, shouldn't it also warn about "auto operator () ( ptr_type &ptr ) -> int const {" (with decltype() replaced by int) here? I guess I should have reported this one as a warning inconsistency.
Vladimir
JenniferJ
The "warning #327: NULL reference is not allowed" is now changed to "remark" in 13.0 update1. Jennifer
