Based on this link http://www.javanb.com/eclipse/1/4758.html, I tried to use Intel C++ Compiler XE 12.0 and integrate with Eclipse IDE for C/C++ Developers with CDT 7.0.2.
I followed these steps:
1)Installed Intel C++ Compiler XE 12.0
2)Modified User Environment Variable INLCUDE and its path is defined as
C:\\Program Files\\Intel\\ComposerXE-2011\\compiler\\include;C:\\Program Files\\Microsoft Visual Studio 10.0\\VC\\include;C:\\Program Files\\Microsoft Visual Studio 10.0\\VC\\atlmfc\\include;
3)Modified User Environment Variable LIB and its path is defined as
C:\\Program Files\\Intel\\ComposerXE-2011\\compiler\\lib\\ia32;C:\\Program Files\\Microsoft Visual Studio 10.0\\VC\\atlmfc\\lib;C:\\Program Files\\Microsoft Visual Studio 10.0\\VC\\lib;
4)Opened Eclipse(CDT), New->C++ Project->project type->Makefile project, named it as "test1".
5)Added a source file into the project, say "test1.cpp".
6)Modified existing"Makefile", with content as the following:
all: test1.exe
test1.exe: test1.obj
icl test1.obj
test1.obj: test1.cpp
icl test1.cpp
clean:
del *.obj
del *.exe
7)Opened Project -> Properties -> C/C++Build -> Builder settings
a)Unchecked "Use default build command".
b)nmake -f makefile CPP=C:\\Program Files\\Intel\\ComposerXE-2011\\bin\\ia32\\icl.exe LINK32=C:\\Program Files\\Intel\\ComposerXE-2011\\bin\\ia32\\xilink.exe
8)Now I built C++ project using Intel C++ Compiler.
it gives message: **** Build of configuration Default for project test1 ****
(Cannot run program "nmake": Launching failed)
How can I make it work?
