Intel® C++ Compiler
7944 Discussions
Use common project files for both Windows and Linux
Sandeep_Kandula
I tried Intel Parallel Studio XE 2011 in Windows 7 and it got integrated well with Visual Studio 2010.
The VC++ 2010 solution and project files which compile and built successfully with VC++ 2010 compiler will compile and built successfully with Intel C++ compiler.
Do Intel Parallel Studio XE 2011 can be integrated with Eclipse in Windows 7? If so, how to proceed?
Can I use the same VC++ 2010 solution and project files in Eclipse with Intel C++ compiler in Linux? If not , are there any party tools to achieve this requirement?
kfsone
Take a look at "CMake".
Sandeep_Kandula
For CMAKE, we need to create a Makefile which will be used to convert project files for respective compiler/IDE.In Visual Studio 2010, there is no option to export a makefile for existing VC++ 6project as available in Visual Studio/VC++ 6.
For example : Visual Studio 6 : http://www.ibm.com/developerworks/opensource/library/os-ecl-vscdt/
