Intel® C++ Compiler
7944 Discussions
Using Intel C++ Compiler to build Firefox on Windows
xunxun
I have built some Firefox editions using Intel Compiler from Firefox 10.
At present, I think the build process, patches, and some bug workaround methods are very stable, so I have reconstructed my wiki.
Wiki English Edition :
http://code.google.com/p/pcxfirefox/wiki/MozillaBuiltICC
Wiki Chinese Edition :
http://code.google.com/p/pcxfirefox/wiki/MozillaBuiltICC?wl=zh-Hans
Hope this can be useful for the people interested in building Firefox using Intel Compiler on Windows.
Latest Firefox 13 x86 edition using ICC13 is here:
http://pcxfirefox.googlecode.com/files/Firefox-13.0-enUS-pcx-win32-120604-icc13-sse2-betterpgo.7z
If you have some problems, you can discuss with me. I won't continue Firefox ICC edition building until I have a strong need because of very much time cost.
JenniferJ
Thank you sharing those instructions.
Did you run any test suite?
Jennifer
xunxun
Jennifer
Here is some test results:
official13 my13 ICC
sunspider 330.8ms +/- 0.7% 284.8ms +/- 1.1%
V8 4803 5084
Kraken 5140.2ms +/- 0.7% 4678.9ms +/- 0.9%
Aquarium 15-16 fps 22-30 fps
Tested on Win7 x64 and Intel Core2 CPU
JenniferJ
Doesn't look bad at all.
Another question, I just read your wiki and saw several issues with Intel C++ compiler. Have you reported all the issues yet?
Thanks again!
Jennifer
xunxun
Thanks again!
Jennifer
I haven't.
Because when I build using IPO&PGO, I usually don't use -Zi (It will cause time long or some build stop if a very many objs), which make me can't debug it.
That is why I can't raise any code change/suggestion for this, and if I report the issue, I don't know how to discribe them...
levicki
Valued Contributor I
I just checked your changes to build environment and this doesn't make sense to me:
- OPTIMIZER += -Ox # maximum optimization for freebl
+ OPTIMIZER += -O2 # maximum optimization for freebl
With Intel Compiler /Ox and /O2 produce the same level of optimization. Perhaps you wanted to put /O3?
xunxun
Quoting Igor Levicki
Please see my
Supplement & Postscript
http://code.google.com/p/pcxfirefox/wiki/MozillaBuiltICC#Supplement_&_Postscript
freebl is a part of security module.
levicki
I did, I just wanted to say that /Ox and /O2 produce same code with ICC:
/O2 optimize for maximum speed (DEFAULT)
/Ox enable maximum optimizations (same as /O2)
xunxun
Oh, I thought Ox is the same as ICC's O3 ago ...
Changing Ox to O2 is not too bad ... :)
