I have built some Firefox editions using Intel Compiler from Firefox 10.
At present, I think the build process, patches, and some bug workaround methods are very stable, so I have reconstructed my wiki.
Wiki English Edition :
http://code.google.com/p/pcxfirefox/wiki/MozillaBuiltICC
Wiki Chinese Edition :
http://code.google.com/p/pcxfirefox/wiki/MozillaBuiltICC?wl=zh-Hans
Hope this can be useful for the people interested in building Firefox using Intel Compiler on Windows.
Latest Firefox 13 x86 edition using ICC13 is here:
http://pcxfirefox.googlecode.com/files/Firefox-13.0-enUS-pcx-win32-120604-icc13-sse2-betterpgo.7z
If you have some problems, you can discuss with me. I won't continue Firefox ICC edition building until I have a strong need because of very much time cost.
Thank you sharing those instructions.
Did you run any test suite?
Jennifer
Jennifer
Quoting Jennifer Jiang (Intel)
Jennifer
Jennifer
Here is some test results:
official13 my13 ICC
sunspider 330.8ms +/- 0.7% 284.8ms +/- 1.1%
V8 4803 5084
Kraken 5140.2ms +/- 0.7% 4678.9ms +/- 0.9%
Aquarium 15-16 fps 22-30 fps
Tested on Win7 x64 and Intel Core2 CPU
Doesn't look bad at all.
Another question, I just read your wiki and saw several issues with Intel C++ compiler. Have you reported all the issues yet?
Thanks again!
Jennifer
Thanks again!
Jennifer
Because when I build using IPO&PGO, I usually don't use -Zi (It will cause time long or some build stop if a very many objs), which make me can't debug it.
That is why I can't raise any code change/suggestion for this, and if I report the issue, I don't know how to discribe them...
I just checked your changes to build environment and this doesn't make sense to me:
- OPTIMIZER += -Ox # maximum optimization for freebl
+ OPTIMIZER += -O2 # maximum optimization for freebl
With Intel Compiler /Ox and /O2 produce the same level of optimization. Perhaps you wanted to put /O3?
Quoting Igor Levicki
Supplement & Postscript
http://code.google.com/p/pcxfirefox/wiki/MozillaBuiltICC#Supplement_&_Postscript
freebl is a part of security module.
I did, I just wanted to say that /Ox and /O2 produce same code with ICC:
/O2 optimize for maximum speed (DEFAULT)
/Ox enable maximum optimizations (same as /O2)
Changing Ox to O2 is not too bad ... :)
