Currently we use Visual Studio 2017 targeting Windows with Visual Studio solutions/projects files.
We want to build/debug our product for both Windows/Linux and trying to use Visual Studio build with cmake.
According to docs.microsoft.com/en-us/cpp/build/cmakesettings-reference?view=vs-2019 :
Any custom environment can be used, or these predefined environments:
linux_arm: Target ARM Linux remotely.
linux_x64: Target x64 Linux remotely.
linux_x86: Target x86 Linux remotely.
msvc_arm: Target ARM Windows with the MSVC compiler.
msvc_arm_x64: Target ARM Windows with the 64-bit MSVC compiler.
msvc_arm64: Target ARM64 Windows with the MSVC compiler.
msvc_arm64_x64: Target ARM64 Windows with the 64-bit MSVC compiler.
msvc_x64: Target x64 Windows with the MSVC compiler.
msvc_x64_x64: Target x64 Windows with the 64-bit MSVC compiler.
msvc_x86: Target x86 Windows with the MSVC compiler.
msvc_x86_x64: Target x86 Windows with the 64-bit MSVC compiler.
(though config dialog also mentions Mingw64 as an option).
Can you give recommendations how to configure VS 2017/2019 cmake to use Intel C++ compiler on both Windows and Linux?
Sergei.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
After you "source /intalled_dir compilervars.csh", then see where gcc/g++ are called in your Makefile thenchange to icc/icpc
Viet,
Thank you for your response.
CMake generates Makefile files (Unix Makefile generator is configured for CMake only for Linux build files output). For Windows, VS2017/2019 with CMake generates Ninja build files.
Therefore, your advice is not applicable.
Sergei.
How to use Intel C++ compiler with VS2017/VS219 CMake "open folder" workflow, I give example for VS2019 and Intel C++ compiler update 4:
1. Create vs2019.cmd with the following text:
call "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2019.4.245\windows\bin\ipsxe-comp-vars.bat" intel64 vs2019
start "VS2019" /B "C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\Common7\IDE\devenv.exe"
2. . Click on vs2019.cmd.
3. In VS2019 edit your CMakeSettings.json config file, add the following (for Release configuration):
"name": "x64-IntelEnv-Release",
"description": "Start visual studio from Intel C++ compiler environment cmd window",
"generator": "Ninja",
"configurationType": "Release",
"buildRoot": "${workspaceRoot}\\..\\cmake-build\\${name}",
"installRoot": "${workspaceRoot}\\..\\cmake-install\\${name}",
"cmakeCommandArgs": "",
"buildCommandArgs": "-v",
"ctestCommandArgs": "",
"inheritEnvironments": [ "msvc_x64_x64" ],
"variables": [
"name": "CMAKE_CXX_COMPILER",
"value": "icl.exe",
"type": "FILEPATH"
"name": "CMAKE_C_COMPILER",
"value": "icl.exe",
"type": "FILEPATH"
4. Select "x64-IntelEnv-Release" in "Configurations" dropbox. Build.
