Intel® C++ Compiler
Using SVM for Intel Graphics Technology
Mathieu_D
I'm writing a benchmark to compare different technologies and their performance accross various platforms (on Linux). One of the platform is an Intel Broadwell-H  (Core i7-5775C with integrated GPU Iris Pro 6200), so I'm testing the various ways to offload a code on my GPU using Cilk Plus. Right now, I'm trying to use SVM so I followed this tutorial but I'm facing some problems. Here's my code :
#include <stdio.h>
#include <stdlib.h>
#include <assert.h>
#include <cilk/cilk.h>
#include <gfx/gfx_rt.h>
#define SIZE 64
int main(){
  int * in = (int*)_GFX_svm_alloc(sizeof(int)*SIZE);
#pragma offload target(gfx)
  _Cilk_for (int i = 0; i < SIZE; i++){
    in = 1;
    assert(in == 1);
  _GFX_svm_free(in);
  return 0;
Then I compile with
 - $ icc -qoffload-svm test.c
test.c(12): error: *GFX* pointer variable "in" in this offload region must be specified in an in/out/inout/nocpy clause
compilation aborted for test.c (code 2)
I thought maybe SVM is not allowed on all patforms, so compiled with
- $ icc -qoffload-arch=broadwell -qoffload-svm test.c
- $ ./a.out
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
a.out test.c:18: main: Assertion 'in == 1' failed.
Abandon (core dumped)
So I guess specifying the platform helps to compile, but the execution failed.
If I change the pragma adding inout(in : length(SIZE)), the compilation/execution works well with the first one, but with the second one we have the same execution problem. The point is : I don't want to add the inout clause, I shouldn't have to. I assume my compilation line is wrong but I can't say in which way.
So my question is : do you see something wrong in my code/compilation ?
Thanks a lot for your time,
Mathieu
Yuan_C_Intel
Hi, Mathieu
What's your Linux graphics driver version? Have you installed the required version from
https://software.intel.com/en-us/articles/getting-started-with-compute-offload-to-intelr-graphics-technology
Could you have a try with option "-qoffload-arch=broadwell:visa3.2" ? I tried your test case on skylake on Windows, it works well.
Mathieu_D
Hi Yolanda,
First, about the driver version :
vainfo: VA-API version: 0.99 (libva 1.7.0)
vainfo: Driver version: 16.5.1.59511-ubit
The driver came with Media Server Studio 2017. I installed it following the instructions here, for Ubuntu 16.04 based on the 4.4 kernel.
I tried using your option to compile :
- $ icc -qoffload-arch=broadwell:visa3.2 -qoffload-svm test.c
- $ ./a.out
a.out: test.c:18: main: Assertion 'in == 1' failed.
Same as before ...
Thank you very much,
Mathieu
Konstantin_B_Intel
SVM is supported exclusively on Windows. Linux is not supported, unfortunately.
Mathieu_D
Okay I understand. It would be nice to find this information directly on this page ... I guess the option qoffload-svm (Linux) exists because you plan to support SVM on Linux on a future release ? Could we have a time estimation ?
Mathieu
