Intel® C++ Compiler
Using SVML
Steena_M_Intel
I am using a single SVML function (___mm256_pow_ps()) among other non-SVML intrinsic functions in my code compiled with icpc. Is the following flag:-fimf-use-svml=true:pow the only one I should be using? I am probably missing something. Is there a different header, in addition to immintrin.h, that should be used? My compilation error is:
error: identifier "__m256_pow_ps" is undefined
Thanks in advance,
Steena
TimP
There isn't a documented explicit interface for calling svml functions.  icpc should do it automatically with standard source code such as
#include <cmath>
float a[].b,c[];
for(int i=0; i<n; ++i)a = pow(c,b);  // or <math.h> and powf()
The fimf options may be used to control which svml functions are used, but the default is to use all of them.  If the vec-report option tells you it is vectorized, this assures you that an svml call is made.   You can check by nm etc.
TimP
#include <cmath>
float a[].b,c[];
Steena_M_Intel
Tim,
Thanks for that explanation. My mistake was mistyping the instruction---m256_pow_ps instead of _mm256_pow_ps.
