Recently, I found Intel post (from 2014) which describes using of arithmetic and logic operators with SIMD data types. I tried to use it in my program, but this doesn't seem to work - compiler just states: "error : no operator "+" matches these operands
1> operand types are: __m128d + __m128d". I'm using Visuald Studio 2019 with Intel C++ Compiler 19.1. I couldn't find anymore information on that feature beside that one link. Is that a deleted feature? Am i doing something wrong? Am I getting something wrong?
- Tags:
- Bug
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
I'm facing a similar issue with SIMD arithmetic ops on VS-2019. Whereas on Linux, arithmetic ops on SIMD works fine.
Could you try building this code snippet on VS-19 and tell us the exact error(screenshot would be better) that you are facing?
#include <immintrin.h> #include <stdio.h> int main() { __m128 a1 = _mm_set_ps(4.0, 3.0, 2.0, 1.0); __m128 a2 = _mm_set_ps(1.0, 2.0, 3.0, 4.0); __m128 res = a1 + a2; //Instead of _mm_add_ps //__m128 res = _mm_add_ps(a1, a2); using function float *f = (float *)&res; printf("%f %f %f %f\n",f[0],f[1],f[2],f[3]); return 0; }
Could you also try using _mm_add_ps() function call to add SIMD datatypes and let us know if it works on VS-19?
Rahul
Hello, Vaidya.
So building this code fails:
Studio also shows two errors (the top one says exactly the same thing as the english one):
The function version works just fine:
Sounds like a bug to me. The documentation is relevant because it works fine on Linux. We will escalate this issue to the concerned team.
Thanks for reporting this.
--Rahul
It may have to do with Microsoft compatibility. CL also gave error
C:\temp>cl t.c
Microsoft (R) C/C++ Optimizing Compiler Version 19.16.27040 for x64
Copyright (C) Microsoft Corporation. All rights reserved.
t.c
t.c(8): error C2088: '+': illegal for union
C:\temp>icl t.c
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.1.216 Build 20200306
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
t.c
t.c(8): error: expression must have arithmetic or pointer type
compilation aborted for t.c (code 2)
C:\temp>notepad t.c
#include <stdio.h>
int main()
return 0;
This issue is fixed in oneAPI2021.2.
$ icpc -V
Intel(R) C++ Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
I am going to close this thread.
