I am trying to upgrade a project to a newer compiler stack and language standard. I end up with some strange errors. I have this command line:
/opt/intel/compilers_and_libraries_2016.4.210/mac/bin/intel64/icpc -D_REENTRANT -DHAVE_GCCVISIBILITY -DMACOSX \ -mmacosx-version-min=10.11 -clangxx-name=/usr/local/llvm-3.9.1/bin/clang++ -std=c++11 -fno-omit-frame-pointer \ -fPIC -fvisibility=hidden -fmath-errno -qopenmp -fp-model precise -g -Wall -Wno-deprecated -pthread -o foo.o -c foo.cpp
It returns:
In file included from foo.cpp(9): bar.hpp(16): catastrophic error: cannot open source file "iostream" #include <iostream> ^ compilation aborted for foo.cpp (code 4)
It builds fine if built for macOS 10.8 and gnu++98.
Another problem that I am facing is that I can't get LLVM functionality, for example llvm::dyn_cast is unknown no matter what I include.
Has anybody faced similar problems?
What I am supposed to source in my case? Can you please give an example? The Intel compiler is installed in /opt/intel/compilers_and_libraries_2016.4.210 while Clang is installed in /usr/local/llvm-3.9.1.
By the way, if I revert to gnu++98 and minimal macos support 10.8, it bulds but the following fails when using LLVM functionality:
#include <llvm/Support/Casting.h> llvm::dyn_cast<FooBar&>(foobar); foobar.cpp(26): catastrophic error: cannot open source file "llvm/Support/Casting.h" #include <llvm/Support/Casting.h>
Supplying -I/usr/local/llvm-3.9.1/include complains about not finding type_traits:
In file included from /usr/local/llvm-3.9.1/include/llvm/Support/Casting.h(19), from foobar.cpp(26): /usr/local/llvm-3.9.1/include/llvm/Support/type_traits.h(17): catastrophic error: cannot open source file "type_traits" #include <type_traits>
If I supply -I/usr/local/llvm-3.9.1/include/c++/v1, the things get completely out of control.
If I instead use the default Clang on Mac, I have the same issues.
