Hi all,
I am using the offload programming model for my project. What I have is a global pointer that I use to allocate memory on the MIC. After doing some more computation on the host I then try to copy the results from host memory to the memory in the MIC using in() for host structure and nocopy() for the global pointer. The documentation and a few of the forum posts say that it should work however in my case it results in a segfault.
What I read:
https://software.intel.com/en-us/articles/effective-use-of-the-intel-com...
The code is something like this:
//This is global
__attribute__((target(mic:0))) wildstruct* foo;
#pragma offload target(mic:0) nocopy(foo) {
foo = malloc(sizeof(foo)); //foo is then initialized later on in this offload region.
In another file:
#pragma offload target(mic:0) in(anotherFoo[0:LENGTH]) nocopy(foo) {
memset(foo,anotherFoo,sizeof(foo)); //segfaults here. foo is NULL which I believe should not be the case according to the documentation.
Thanks!
Difficult to say what is problem without the complete code.
Is the pointer foo also declared with target attribute in the second file
