Intel® C++ Compiler
7953 Discussions
Using masm inline assembler on 64bit compiler, fails when I use the 32bit compiler
Mike_Korzenowski
This is hard to figure out, help would be appreciated.
 have the following code segment compiling and linking and executes when I use the Intel Compiler 64bit version, however I get the following error when I use th 32bit compiler.I have included the switches also:
icpc -O2 -Wall -m32 -g3 -use-masm
error: label "RAX" was referenced but not defined, mov RAX, 0x1
compliation aborted (code 2)
unsigned long long regRAX = 0;
__asm
mov RAX, 0x1
CPUID
move regRAX, RAX
SergeyKostrov
Valued Contributor II
You're trying to compile 64-bit assembler codes with 32-bit C++ compiler and, of course, it is Not supported. Here is a small example: RTbool IsCPUFeaturePresent( RTuint uiRequestFeature ) { RTuint uiFeatureRegCX = 0x0; RTuint uiFeatureRegDX = 0x0; __try { _asm { MOV eax, 1 CPUID MOV uiFeatureRegCX, ecx MOV uiFeatureRegDX, edx } } ...
