Dear Intel developers,
I'm using intel 15 on E5-2670 processor. Analyzing my code by using Vtune, in a particolar line when I unpack a m128 type in order to sum in a single floating point each elements like horizontal sum, like this:
_mm_store_ps(denom_arr_tmp, denom_tmp); semblance[m_local] += denom_arr_tmp[0]+denom_arr_tmp[1]+denom_arr_tmp[2]+denom_arr_tmp[3];
The assembly generated is:
vunpckhps %xmm2, %xmm2, %xmm3 movq -0x80(%rbp), %rax vaddssl -0x9c(%rbp), %xmm2, %xmm4 vaddss %xmm3, %xmm4, %xmm5 vaddssl -0x94(%rbp), %xmm5, %xmm6 vaddssl (%rax,%r14,4), %xmm6, %xmm7 vmovssl %xmm7, (%rax,%r14,4)
My question is: what is VADDSSL instruction? What's the difference with VADDSS? How I can optimize that piece of code? Actually is a bottleneck.
if you are using GAS/AT&T syntax, it uses postfix/Operation Suffixes in the instruction name,
l normally stands for long, see like here http://en.wikibooks.org/wiki/X86_Assembly/GAS_Syntax
Can you defer your horizontal add (move it out one loop level)? IOW have the inner loop accumulate the denom_tmp's into semblance_tmp, then in the next outer loop perform the horizontal add across semblance_tmp into semblance?
Jim Demspey
Hi Maxym, from your link I read thay "l" stand for:
- l = long (32 bit integer or 64-bit floating point)
so the compiler are using 64 bit floating point? If yes what's the possible reason? I'm using 32 bit floating point. Thanks.
Jim Demspey
Thanks Jim, I'll try your suggest paying attention to the results.
