Intel® C++ Compiler
7956 Discussions
VS 2022 Intellisense not recognizing ICX predefined macros
wmeier
Using the Intel C++ 2022 compiler (Version 2022.0.0 Build 20211123) in Visual Studio 2022, Intellisense does not recognize ICX compiler predefined macros such as __INTEL_LLVM_COMPILER and __clang__.
VS 2022 Intellisense does work with Intel C++ 19.2, recognizing __INTEL_COMPILER as a predefined macro.
Is there a fix for ICX integration into VS 2022?
VarshaS_Intel
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
Yes, this is a known issue and will be fixed in future updates.
As of now, please find the below workaround:
1. In Visual Studio Project properties, Go to Configuration Properties --> C/C++ --> Preprocessor -->Preprocessor Definitions then add __INTEL_LLVM_COMPILER=202110
Please find the below screenshot for more details:
Thanks & Regards,
Varsha
VarshaS_Intel
Thanks & Regards,
Varsha
VarshaS_Intel
I could see you have marked the reminder reply as a solution. Did the solution provided by us help you? If yes, then can we go ahead and close this thread?
Thanks & Regards,
Varsha
wmeier
Yes, the provided solution helped me, thank you.  Please close thread.
VarshaS_Intel
Thanks for the confirmation.
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Have a Good day!
Thanks & Regards,
Varsha
