Using the Intel C++ 2022 compiler (Version 2022.0.0 Build 20211123) in Visual Studio 2022, Intellisense does not recognize ICX compiler predefined macros such as __INTEL_LLVM_COMPILER and __clang__.
VS 2022 Intellisense does work with Intel C++ 19.2, recognizing __INTEL_COMPILER as a predefined macro.
Is there a fix for ICX integration into VS 2022?
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Varsha
Yes, this is a known issue and will be fixed in future updates.
As of now, please find the below workaround:
1. In Visual Studio Project properties, Go to Configuration Properties --> C/C++ --> Preprocessor -->Preprocessor Definitions then add __INTEL_LLVM_COMPILER=202110
Please find the below screenshot for more details:
Thanks & Regards,
Varsha
Thanks & Regards,
Varsha
I could see you have marked the reminder reply as a solution. Did the solution provided by us help you? If yes, then can we go ahead and close this thread?
Thanks & Regards,
Varsha
Yes, the provided solution helped me, thank you. Please close thread.
Thanks for the confirmation.
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Have a Good day!
Thanks & Regards,
Varsha
