Intel® C++ Compiler
7953 Discussions
VS2008 Debug Error related to MKL - Entry Point Not Found
Allison_G_
I have the Intel 11.1.035 compiler integrated in VS2008 Pro. I use Intel C++ Compiler Pro -> Select Build Components by right-clicking my project name in Solution Explorer to select TBB and MKL libraries to use with my release and debug configurations. I select Sequential in the MKL option (application is already parallelized with TBB) for both release and debug configurations. The Release build works just fine but debugging generates an "Entry Point Not Found" error.
The Select Build Components causes these libraries to be linked for the debug configuration (MKL linker tool will suggest the same):
mkl_solver.lib mkl_intel_c_dll.lib mkl_sequential_dll.lib mkl_core_dll.lib
The error is titled "Entry Point Not Found" and the message is: the procedure entry point mkl_lapack_dgesv could not be located in the dynamic link library mkl_sequential.dll
The build output is:
'model6_1.exe': Loaded 'C:\Documents and Settings\GehrkeA\My Documents\Visual Studio 2008\Projects\model6_1\Debug\model6_1.exe', Symbols loaded.
'model6_1.exe': Loaded 'C:\WINDOWS\system32\ntdll.dll'
'model6_1.exe': Loaded 'C:\WINDOWS\system32\kernel32.dll'
'model6_1.exe': Loaded 'C:\Program Files\Intel\MKL\10.0.5.025\ia32\bin\mkl_sequential.dll', Binary was not built with debug information.
'model6_1.exe': Loaded 'C:\WINDOWS\system32\msvcr71.dll'
Debugger:: An unhandled non-continuable exception was thrown during process load
The program '[216] model6_1.exe: Native' has exited with code -1073741511 (0xc0000139).
The three Intel parallel Debugger Extensions are selected under Debug-> Exceptions->Win32 Exceptions; but have tested with them selected and not and doesn't seem to make a difference to my debug error.
Please advise how I can correct this error in order to debug my application.
Thanks, Allison
JenniferJ
Quoting - asgehrke
'model6_1.exe': Loaded 'C:Documents and SettingsGehrkeAMy DocumentsVisual Studio 2008Projectsmodel6_1Debugmodel6_1.exe', Symbols loaded.
'model6_1.exe': Loaded 'C:WINDOWSsystem32ntdll.dll'
'model6_1.exe': Loaded 'C:WINDOWSsystem32kernel32.dll'
'model6_1.exe': Loaded 'C:Program FilesIntelMKL10.0.5.025ia32binmkl_sequential.dll', Binary was not built with debug information.
'model6_1.exe': Loaded 'C:WINDOWSsystem32msvcr71.dll'
At build time, the IDE integration selected the correct libraries from the 11.1.035 directory.
At run time/debug, the "path" seems having the 10.0.5.025 in front of 11.1.035. Please do this:
1. close VS
2. update the system path to include 11.1.035's mkl bin directory
3. open VS again to debug.
Jennifer
Allison_G_
1. close VS
Jennifer
Thank you. That fixed it. Note: the 11.1.035's mkl bin directory was in my system Path but mkl 10.0.5.025 was also, so I deleted it and that worked.
Allison
