I had vTune 9 installed and everything was ok. After installing latest C++ compiler (with integration to VS2005), loading a project takes a few minutes(!) during which the devEnv is reading repeatability some files (list available).
I removed the vtune integration, but still the problem persists.
Configuration:
VS 2005, 8,0.50727.42 (without SP1)
Intel C++ compiler integration: 10.1.689.2005
vTune
top of stack trace (captured using ProcMon from the file access)
C:WINDOWSMicrosoft.NETFrameworkv2.0.50727diasymreader.dll
C:Program FilesIntelVTuneAnalyzerBinCPI.dll
Any help would be appreciated.
when you remove VTune integration, did you remove it from "Add/Remove" program? it's strange that the VTune cpi.dll is also invoked.
Can you try on a different machine without VTune 9? or please attach the .vcproj file so I can try.
Jennifer, this may be the VTune issue. I have VS2008, VTune 9.0 update 7 and ICC 10.1.021 installed. Check this thread and look for the issue #8 in the list I made. Check attached screenshots as well.
I used the Add/Remove and chose "Modify" when the installshield window opened. Then removed the integration part.
When I renamed cpi.dll , performance got ok again.
My solution file contains several projects. At first I thought the project was defective, but when removing it (simply renaming the vcproj file), another project took the fire when trying to load.
By the way: running vTune instandalone , (with cpi.dll proper name), the profiling is working. However, I get strange results -- parts of it due to my full ignorance in this tool no doubt. The Tunning advice is just showing clock ticks. the sample code (in the tutorial ) tends to crash (maybe we can get some insight from this?)
thanks
Noam C.
thanks. it worked.
Every time vTune crashes (yes, it happens occasionally), the env variables should be checked
