Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7693 Discussions
Value of 1E10 when assigned to an integer is different in intel C++ and visual studio MSVC compiler
pradeep_s_
The integer value is different for intel C++ compiler and visual studio MSVC compiler.
The value of 1E10 when assigned to an integer is "1410065408" for MSVC compiler  and whereas for intel C++ is "-2147483648". Could you explain why the value is not same for both the compilers.
Due to this the same code is causing runtime exceptions when compiled through intel C++ compiler.
Pradeep
jimdempseyatthecove
Black Belt
1E10 is beyond the range of int (32-bit integer). Thus behavior is undefined.
Consider using int64_t integer type for numbers that large.
Jim Dempsey
jimdempseyatthecove
Black Belt
Jim Dempsey
pradeep_s_
Hi Jim Dempsey,
Thank you for the prompt response.
Pradeep
