Intel® C++ Compiler
7956 Discussions
Variable initialization with a function?
Tang__Yaotian
I tried to initialize a local variable by invoking a function, but the compiler reports the variable was declared but never referenced. Is this because I missed some compilation parameters? This error also happens if I use compiler intrinsics to initialize a variable.
Viet_H_Intel
a was not referenced in your program. You can suppress the error by adding -wd177
