Hi all!
Although this code has many features that are strictly forbidden by the C standard I think most of them are supported as Intel extensions.
#include <stdlib.h>
#include <stdio.h>
#if defined(RANK)
#define IRANK RANK
#else
#define IRANK 0
#endif
#define MSTRUCT(r) struct{int dim
int main(int argc, char **argv){
int n = IRANK;
MSTRUCT(n) s;
printf("%zu, %zu\n", sizeof(s), sizeof(MSTRUCT(n)));
return EXIT_SUCCESS;
I would expect the code to print two identical numbers.
Using -ftrapuv changes the value printed, -O0 had the same effect on a more complicated variation.
Thank you very much.
José Rui
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
This code has an uninitialized variable "int dim[0];" which can lead to undefined behavior.
I meant is "variable length array" not "uninitialized variable"
Yes, the code has several features that are not standard conforming, but I think that some of them are supported by Intel as extensions.
José Rui
