I am re-posting this as I think Intel only replies to new posts.
I am using Intel Compiler C++ XE 2015 Update 6, with Visual Studio 2013 ( 64-bit code). When in full debug mode variables that are declared in "nested scope(s)" in a function ( for example declared local inside for loop) are completely invisible to the Visual Studio debugger... this makes debugging a complete and utter nightmare. I am compiling /Zi /Od and linking with appropriate options.
Switching back to Visual C++ as the compiler, corrects the issue. Does anyone have an idea why this is happening or a workaround?
Hi @vasci_,
I've escalated this to the engineering team and will keep you updated accordingly. This is based on a test case filed similar to this issue. BTW, if you also do have a small reproducer appreciate if you can attach as well?
Kittur
Sorry, small test cases seem to work fine.
This problem has been in the Intel Compiler for some time. It seems to come and go. I am at my "wits end" at the moment as I am having to do bad things to my code by changing all variables to "function scope" just to debug., or resort to "print" statements, sadly.
Understood, thanks for your patience @vasci_. This issue has been escalated at a higher priority to the product team and will keep you updated.
Kittur
Has any progress been made on this? Or tips to avoid the issue. It is becoming almost impossible to debug.
Hi @vasci_,
The latest status I have on this issue is that it's being worked on but I don't have an estimate on when the release with the fix will be out. There's no workaround as well (presently). BTW, I'll be transitioning so my peer would be supporting you on this going forward and will keep you updated. Again, your patience, as always is much appreciated.
Kittur
Thanks, at least the problem is recognised and reproducible.
No trying to read too much into your 'transitioning ' comment but I do hope that the Intel layoffs are not affecting the tools group. I think Intel may need to give some reassurance as to the state of their on-going commitment to desktop compilers and tools (MKL, IPP ,TBB etc)
Of course, you're right. The compilers and other SW products are completely supported with the same excellence you've been receiving all these years. Good point though and thanks for continuing to file issues and for your feedback, which helps us improve our products further, appreciate much.
Kittur
For more complete information about compiler optimizations, see our Optimization Notice.
