Intel® C++ Compiler
Vectorization and cache
nik0las
I'm trying to speed up some code using auto vectorization from Intel Compiler and using sse. All computations are transformation some struct node_t to another struct w_t (functions tr() and gen_tr()). When I try vectorize function gen_tr() it does not produce any effects.
If change data storage format, when each struct component stored in different array of floats, then auto vectorization works well, see function genv_tr().
Function that used sse called ssev_tr (N should divided evenly by 4).
transform.c:
[cpp]#include
#include
#include
#include
static __inline__ unsigned long getCC(void)
    unsigned a, d;
    asm volatile("rdtsc" : "=a" (a), "=d" (d));
    return ((unsigned long)a) | (((unsigned long)d) << 32);
typedef struct {
    float x1, x2, x3, x4, x5;
} node_t;
typedef struct {
    float w1, w2, w3, w4;
} w_t;
void tr(node_t *n, float c1, float c2, w_t *w)
    const float nv = n->x1;
    const float N00T = n->x3 * c1;
    const float n1v = n->x2;
    const float N01T = n->x4 * c2;
    w->w1 = nv  - N00T;
    w->w2 = nv  + N00T;
    w->w3 = n1v - N01T;
    w->w4 = n1v + N01T;
__attribute__ ((noinline))
void gen_tr(node_t *n, w_t *w, const int N, float c1, float c2)
    int i;
    #pragma vector aligned
    #pragma ivdep
    for (i = 0; i < N; i++) {
        tr(n + i, c1, c2, w + i);
void genv_tr(float *x1, float *x2, float *x3, float *x4, float *x5, float *w1, float *w2, float *w3, float *w4, const int N, float c1, float c2)
    int i;
    #pragma ivdep
        const float N00T = x3 * c1;
        const float N01T = x4 * c2;
        w1 = x1 - N00T;
        w2 = x1 + N00T;
        w3 = x2 - N01T;
        w4 = x2 + N01T;
void ssev_tr(float *x1, float *x2, float *x3, float *x4, float *x5, float *w1, float *w2, float *w3, float *w4, const int N, float c1, float c2)
    __m128 *ws1 = (__m128*)w1;
    __m128 *ws2 = (__m128*)w2;
    __m128 *ws3 = (__m128*)w3;
    __m128 *ws4 = (__m128*)w4;
    __m128 *xs1 = (__m128*)x1;
    __m128 *xs2 = (__m128*)x2;
    __m128 *xs3 = (__m128*)x3;
    __m128 *xs4 = (__m128*)x4;
    const __m128 cs1 = _mm_set1_ps(c1);
    const __m128 cs2 = _mm_set1_ps(c2);
    int i;
    #pragma ivdep
    for (i = 0; i < N / 4; i++) {
        const __m128 N00T = _mm_mul_ps(xs3, cs1);
        const __m128 N01T = _mm_mul_ps(xs4, cs2);
        ws1 = _mm_sub_ps(xs1, N00T);
        ws2 = _mm_add_ps(xs1, N00T);
        ws3 = _mm_sub_ps(xs2, N01T);
        ws4 = _mm_add_ps(xs2, N01T);
#define test(func) \
    for (i = 0; i < n; i++) { \
        x.x1 = 1.0; \
        x.x2 = 2.0; \
        x.x3 = 2.0; \
        x.x4 = 2.0; \
        x.x5 = 2.0; \
    t1 = getCC(); \
    for (i = 0; i < rep; i++) { \
        func(x, w, n, c1, c2); \
    t2 = getCC(); \
    printf("\t%f", ((double)(t2 - t1)) / n / rep);
#define test1(func) \
        x1 = 1.0; \
        x2 = 2.0; \
        x3 = 2.0; \
        x4 = 2.0; \
        x5 = 2.0; \
    t1 = getCC(); \
        func(x1, x2, x3, x4, x5, w1, w2, w3, w4, n, c1, c2); \
    t2 = getCC(); \
int main(int argc, char *argv[])
    if (argc < 2) {
        printf("Usage %s vector_size\n", argv[0]);
    int n = atoi(argv[1]);
    printf("%d", n);
    int rep = 100000000 / n;
    int i;
    int inc = 1;
    float c1 = 2.0, c2 = 1.0;
    unsigned long t1, t2;
    node_t *x = (node_t*)malloc(n * sizeof(node_t));
    w_t *w = (w_t*)malloc(n * sizeof(w_t));
    float *x1 = (float*)malloc(n * sizeof(float));
    float *x2 = (float*)malloc(n * sizeof(float));
    float *x3 = (float*)malloc(n * sizeof(float));
    float *x4 = (float*)malloc(n * sizeof(float));
    float *x5 = (float*)malloc(n * sizeof(float));
    float *w1 = (float*)malloc(n * sizeof(float));
    float *w2 = (float*)malloc(n * sizeof(float));
    float *w3 = (float*)malloc(n * sizeof(float));
    float *w4 = (float*)malloc(n * sizeof(float));
    test(gen_tr);
    test1(genv_tr);
    test1(ssev_tr);
    printf("\n");
    return 0;
}[/cpp]
Compile options: icc -O3 -Wall -W -vec-report6 transform.c -o transform
Version of icc - 12.1.2, OS - Fedora 16 x86_64, CPU - Intel Core2 Quad CPU Q8200.
Then i run it with different size from 16 to 3000 with step 64, here script:
[bash]#!/bin/bash
echo "" > run.log
for ((c=16;c<3000;c+=64))
do
./transform $c | tee -a run.log
done[/bash]
Here some result of work this script (size, gen_tr, genv_tr, ssev_tr), all times shown per one array element:
[plain]16      7.710743        3.168577        3.253829
272     7.166493        1.983918        2.618569
528     7.121866        1.920195        2.567109
784     7.115007        1.899451        2.549645
1040    8.104026        2.481062        2.944317
1296    8.137537        5.105032        5.104614
1552    8.118534        5.068812        5.064211
1808    8.138309        5.077831        5.085015
2064    8.149699        5.107503        5.069958
2320    8.164556        5.080981        5.099313
2576    8.151524        5.086056        5.089294
2832    8.212946        5.061927        5.072261[/plain]
why it is so significant change about size 1000 when using vectorized version of function? Does it because of cache miss? Is it possible to save same speed on all data ranges?
TimP
Black Belt
It seems likely that you are seeing a cache or DTLB miss effect. Remember that hardware prefetch stops at 4KB page boundary. Did you try adjusting opt-prefetch level?
Did you check whether the compiler is splitting the loops, and use #pragma distribute point to control it? Such effects occur when the loop is split between uses of the same array section.
jimdempseyatthecove
Black Belt
Also, check to verify your allocations are vector aligned. Some heap managers allocate to 8-byte granularity.
