Greetings,
I have been trying to use ICC for vectorization but have been having some serious problems.
Even in very simple situations the compiler does not vectorize code that, in principle, seems
straightforward to vectorize. In most cases the vectorization report produces mysterious and
(to me useless) remarks. Please see the test case below:
[cpp]#includevoid initialize(float * A, float * b, size_t Size) { for (size_t row_index = 0 ; row_index < Size ; ++row_index) { float * row = A + row_index * Size ; for (size_t col = 0 ; col < Size ; ++col) { row[col] = 1.0f / float(col + 1) ; } b[row_index] = row_index ; } } void matVec(float const * A, float const * x, float * b, size_t Size) { for (size_t row_index = 0 ; row_index < Size ; ++row_index) { float const * row = A + row_index * Size ; float row_accumulator = 0 ; // Vectorizes for (size_t col = 0 ; col < Size ; ++col) { row_accumulator += row[col] * x[col] ; } b[row_index] = row_accumulator ; } } // The Tonly difference from matVec is that row_index is an int. void matVec2(float const * A, float const * x, float * b, size_t Size) { for (int row_index = 0 ; row_index < Size ; ++row_index) { float const * row = A + row_index * Size ; float row_accumulator = 0 ; // Does not vectorize: // remark: loop was not vectorized: dereference too complex. // If I compile with -vec-report=3 I get a bunch of weird remarks // regarding flow dependence between row_accumulator and itself. // Does this have to do with some unrolling of the outer loop? for (unsigned col = 0 ; col < Size ; ++col) { row_accumulator += row[col] * x[col] ; } b[row_index] = row_accumulator ; } } int main() { size_t const Size = 256 ; float * A, * b, * x ; // I wanted memory aligned to 16 bytes but I am not really // even getting to that. posix_memalign((void**)&A, Size * Size, 16) ; posix_memalign((void**)&b, Size * Size, 16) ; posix_memalign((void**)&x, Size * Size, 16) ; initialize(A, b, Size) ; matVec(A, x, b, Size) ; return 0 ; } [/cpp]
matVec vectorizes well. However matVec2 does not. The only difference between matVec and
matVec2is the type used for the row_index. Looking at the vectorization report I get very cryptic
messages. I even get messages saying that the matVec loop was not vectorized ... then that it was
vectorized:
simple.cpp(60): (col. 5) remark: loop was not vectorized: not inner loop.
simple.cpp(60): (col. 5) remark: loop was not vectorized: unsupported data type.
simple.cpp(61): (col. 5) remark: loop was not vectorized: not inner loop.
simple.cpp(61): (col. 5) remark: loop was not vectorized: existence of vector dependence.
simple.cpp(61): (col. 5) remark: vector dependence: assumed ANTI dependence between (unknown) line 61 and (unknown) line 61.
simple.cpp(61): (col. 5) remark: vector dependence: assumed FLOW dependence between (unknown) line 61 and (unknown) line 61.
simple.cpp(61): (col. 5) remark: LOOP WAS VECTORIZED.
simple.cpp(14): (col. 5) remark: loop was not vectorized: not inner loop.
simple.cpp(20): (col. 9) remark: loop was not vectorized: existence of vector dependence.
simple.cpp(21): (col. 13) remark: vector dependence: assumed ANTI dependence between row_accumulator line 21 and row_accumulator line 21.
simple.cpp(21): (col. 13) remark: vector dependence: assumed FLOW dependence between row_accumulator line 21 and row_accumulator line 21.
simple.cpp(20): (col. 9) remark: LOOP WAS VECTORIZED.
simple.cpp(31): (col. 5) remark: loop was not vectorized: not inner loop.
simple.cpp(41): (col. 9) remark: loop was not vectorized: existence of vector dependence.
simple.cpp(42): (col. 13) remark: vector dependence: assumed ANTI dependence between row_accumulator line 42 and row_accumulator line 42.
simple.cpp(42): (col. 13) remark: vector dependence: assumed FLOW dependence between row_accumulator line 42 and row_accumulator line 42.
simple.cpp(42): (col. 32) remark: loop was not vectorized: dereference too complex.
simple.cpp(4): (col. 5) remark: loop was not vectorized: not inner loop.
simple.cpp(6): (col. 9) remark: loop was not vectorized: unsupported data type.
These messages don't tell me anything about the "row_index int".
I am compiling this code with:
icpc (ICC) 11.1 20090630
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
icpc simple.cpp -O3 -xW -fp-model fast -o simple -vec-report=3
Greetings,
vectorized:
The issue is resolved in Intel Composer XE 16.0.
